21611 Discussions
Problem with Quartus II (Web edition) RTL simulation with Modelsim (student edition)
I recently installed both Quartus and Modelsim. The problem is, i'm unable to simulate with modelsim. After relentlessly browsing the web, i figured i need to choose modelsim as my simulator and output directory as > simulation/modelsim in the settings of the project.
I also came across the settings in the Tool menu. Tool>option>EDA too option>Modelsim-Altera. But the path is causing problem. I came across that we need to set it at -->c:\altera\12.1\modelsim_ase\win32aloem but i'm unable to find it...
Here's the snapshot when i run the rtl simulation
Please guide me with the process...
Thank you.
Obviously, you haven't installed ModelSim, else you would have a 'modelsim_ase' subdirectory.
i recently try to download & install the v10.1 of altera complete design ;but the problem is when i finishid the instalation i m in frot of this error
error is "an error occured when downloading ,do you want to retry the download?
--- Quote Start ---
--- Quote End ---
I have installed model sim. Modle sim student edition which is 180 days trial version. But i'm not sure what to route the path to....
If you effectively installed it, the path is easy to find:
assuming you are using windows
click Start
click All Programs
scroll to the folder named ModelSim or similar, click on it
then right-click on the Modelsim executable and select 'Open File Location' from the pop-up menu, a WIndows Explorer Window will open.
Right-click in the address-filed of that window explorer window and select Copy Address from the pop-up.
Paste that in the appropriate place in Quartus' Assignments->Settings->Eda Tool Settings.
I gather somebody else will help you with Linux, if that is what you are using.
