21615 Discussions
Programmable pull-up resistor in Cyclone II
Dear Sir,
I've a question about the pull-up resistor. Suppose, the pull-up resistor
is related to the I/O voltage Vccio and current strength, isn't it? Why does
it show the resistor is about 10KOhm to 50KOhm in the table5-3 of Cyclone
II Device handbook chapter 5?
For example, Vccio=3.3V, Current strength 16mA in Default of LVTTL.
The pull-up is supposed to be around Rpull-up = (3.3/16)KOhm, isn't it?
Peter Chang
--- Quote Start ---
Suppose, the pull-up resistor is related to the I/O voltage Vccio and current strength.
--- Quote End ---
It isn't. The value is fixed, but subject to PVT (process, voltage, temperature) variations.
Dear Sir,
But I could see a similar example from the page of 8-3 to 8-5 in the MAXII Device Handbook, max2_mii5v1.pdf. It is for the REXT. It, however, is able
to be used for an internal resistor, RINT, isn't it?
Peter Chang:confused:
In the device handbook, the minimum value for an external pull-up resistor is calculated. The internal pull-up resistor is in contrast a weak pull-up with a resistance several orders of magnitude above this minimum value.
Dear FvM,
Why do we need both? Suppose, we need only either internal or external
resistor, needn't we?
Peter Chang
They each serve a purpose. The extern pull-up discussion e.g. has the title max ii device compatibility with 5.0-v cmos devices.
Dear FvM,
Do you mean the example is only more like a voltage shiffter? Can the pull-up resistor not be calculated in the same way as the example?
Thank you!
Peter
The example is in fact for Multi-IO voltage respectively level conversion, it uses the MAX II output in open-drain configuration. In the example, a minimum value based on the available output current is calculated. But in an application, a higher value may be appropriate.
