- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Configuration is :
Windows 10
Max V CPLD Development Kit (low cost)
Type A-B USB cable
Quartus Prime Programmer Lite Edition
Sometimes but rarely I can upload my design (verilog) into the device (5M570ZF256) .
But more frequently I cannot and get the error message as show into the attached pdf file (screenshot)
Could you help me ?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Today, I have received a new board from my retailer.
It seems to work well.
So, this confirm it was a failure on the card, probably a bad contact at the level of USB plug.
As the retailer ask me not to return the board but to discard it, I will try to redo some welds
Thanks for your help.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
May I know if you are using the correct file to programmed into the Max V device? Could you provide me the full Quartus Programmer screenshot?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sometimes it works. Here is a screenshot when it works
But generally it don't work. Maybe is it a bad contact at the level of the USB connector on the board ...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
When you mention sometimes it is working and sometime it is not working, is it using the same file? This might happen if there is some Signal Integrity issue happening on the JTAG interface
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yes, it is with the same file.
When it is working, then it important not to touch anything (no power down, no cable unplug), so I have a kind of "working session" and then I can upload my various designs (.pof files) without problem.
Conversely, when its not working good, then I am unable to upload the same files. It seems more and more obvious that it is a hardware failure at the USB level ...
I contacted my retailer (RS-Components, France) for a exchange of the development kit ... waiting for his reply ...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I think this might be possible issue. I hope that you are able to resolved the issue with the replacement board.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sure. Glad to hear that issue with the new board
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
