21615 Discussions
Pull-up On I/o Pin
Bye everyone,
I'm a beginner on Altera software development tool.
Can you show me the procedure to set a pull-up on I/O pin,
on the documentation i found:
"In the Assignment Editor, set the weak pull-up assignment to ON to enable the on-chip pull-up resistor for the pin."
but it isn't usefull for me.
I'm working with a device of CycloneII, EP2C8F256C7 and Quartus II 8.0sp1 as development tool.
Tanks in advance, i'm looking forward for your answer.
Bye
Giordano
--- Quote Start ---
--- Quote End ---
Why, did you try? The procedure generally works.
You also can enable weak pull-ups in Pin Planner, after showing the respective column through customize menu.
Thank you,
I set the weak pullup in Pin Planner.
It works correctly.
