21611 Discussions
Q: how to combine a Project with its modules into One file to use in another Project
Hi. I would like to combine or package a project I created and tested (in verilog) so I can use it like an IP or as a single module in another project. For example: my top level module has other modules, assignments for timing analysis (e.g. falls paths, multicycle definitions) and *.mif memory initialization file. Now I would like to use that design in a new project and be able to change and update it's *.mif file with out directly adding all of its modules and assignments.
What is a good strategy for using other projects in this way with in your current project.
Do I need Subscription version of Quartus?
Any help or hints would be greatly appreciated. Thankx.
Note: I'm using Quartus II v9.1 Web Edition and design is in Verilog.
No need for subscription edition.
Just include the same file by using relative paths, (it's better than absolute, but not a hard requirement)
Make the file parameterizeble via parameters (verilog) or generics (VHDL)
And that is it.
