I don't know what just happened, but when I compile my previous project (with QII 11.1) with QII 12.1 the I get the fitter error!
It seems all my projects use more LUTs by 12.1, in example my latest project in 11.1 was abou 13KLUT but with 12.1 synthesizer estimates 47KLUTs.:confused: Can anyone explain this to me? what just happened? same vhdl code with different LUTs size!!!!!!Link Copied
Look at the individual component resource usage. Compare each vs your compile with QII 11.1. (Compile your design into a much larger part for QII 12.1 if you need to.
I'll bet that one of your components had a RAM/ROM block that may have synthesized into LUTs instead of a memory block. You could also check the warnings for your compile. It may give you hints as to what has happened.
