21615 Discussions
Stratix IV Tecnical Problem
Dear Sir
I have bought Stratix IV 4SGX230N from your site. We have read that this board supports SFP-HSMC card. Therefore we need to buy this card but our research needs high speed up to 10GB. My question is that can this board with SFP-HSMC card accept SFP+, XFP?.
My Best Wishes
Waddah
You did not buy the kit from this site. This is a user-maintained forum.
Stratix IV GX devices do not support 10.3125Gbps transceiver rates.
Stratix IV GT devices do, and Stratix V devices do.
Cheers,
Dave
Thank you for your replaying
Is the board (DUAL XAUI TO SFP+ HSMC BOARD) suitable with Stratix IV 4SGX230N to achieved up to 10Gbps ?
Waddah
--- Quote Start ---
--- Quote End ---
Do you have a link to the board?
XAUI is 4 x 3.125Gbps, so if the board you refer to has a PHY chip that takes in XAUI and outputs 10.3125Gbps to SFP+, then yes, it would work with the Stratix IV GX FPGA.
Cheers,
Dave
Yes i have the link ,but i can't send it you here .
Please give you your e.mail.
Its staring you in the face ... its my forum name :)
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=71&no=597&partno=2
Yes, this board will do what you need.
NOTE: the HSMC connector on the Stratix IV GX kit supports 8 transceivers on the connector on the left, but only 6 on the right, so you can only use one of these boards and get two SFP+ ports. You might be able to add a second board, but you would only get one more SFP+ port.
Cheers,
Dave
Thank you very much
How can i buy it?
I need it as soon as possible
--- Quote Start ---
How can i buy it?
--- Quote End ---
Contact Terasic.
Cheers,
Dave
I want to Test Designs Using Stratix IV GX FPGA Development + Dual xaui SFP HSMC
this required (hsmc_loopback.sof)
How can i find this file
--- Quote Start ---
--- Quote End ---
From its name, hsmc_loopback, it implies loopback at the HSMC. This is not what you want for testing a XAUI/SFP+ HSMC board. Terasic likely have an example for that.
I am sure there are several layers of loopback;
1) A simple loopback where data from SFP+ is received over XAUI and then sent back over the link.
2) A more complex loopback where data is received as 10GbE packets and the contents checked.
You'll want to perform both sorts of checks.
Cheers,
Dave
Thank for your reply
i just implement the setting in the attached file
you can page 29 step 6
waddah
I did find this file
hsmc_loopback.sof
Would you like please send me the pin information of Stratix V 5SGTMC7K2F40C2ES and EP5SGXEA7N2F40C2N devices ?
