Since it became necessary to replace the EPCS device with the EPCQ-A device,
I need quartus-13.1.4-4.70r patch file, which supports EPCQ-A.
I have Quartus II 32-bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition installed.
Where can i find the link for the 13.1.4 patch 4.70r file? Do I just need to install the patch or do I need to install the entire Quartus II?
Have you checked here:
Look under the 'Updates' tab on the far right hand side. There are multiple update files listed as available for download.
May I know if there is any update from previous reply?
The latest update for v13.1 shown on the Intel site (given by _AK6DN_) is v13.1.4.182. I installed this but none of the EPCQ-A devices are listed under Configuration Devices on the Convert Programming Files page.
Where can I find the 13.1.4 patch 4.70r file download?
Hi Chris,
I am sending something to your email. Please check it.
I haven't received anything yet. Has it been sent?
I have resent to your email. Please check it.
Thanks, but it looks like Intel IT has blocked the messages:
Nothing in the message got through. Is there another way to get this?
I will create FTP and send those information to your email.
I have sent those to your email.
You also may check you private message in your forum. There is a private message feature in this forum, I have sent the patch there and alternative to download the patch via FTP. Let me know
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
Hello Syafieq,
Thanks. I installed FileZilla and attempted to connect to the FTP but kept getting this error message:
Can you help?
Chris
Did you able to look at the private message in your forum?
I send the patches there.
Let me know
