Programmable Devices
21615 Discussions
Quartus Internal Error Advice
When compiling I get the following error in a window. It happens during the Fitting section of compile.
Internal Error: Sub-system: CDB_ATOM, File: /quartus/db/cdb_atom/cdb_atom_sys.cpp, Line: 1338
implements(type)
Processors in use: 4
Stack Trace:
0x6a963: SIN_VALUE_UTILS::get_io_pad + 0x1f3 (TSM_SIN)
0x606a9: Sin_Unload + 0x8bb9 (TSM_SIN)
End-trace
Quartus II Version 9.1 Build 304 01/25/2010 SJ Full Version
Service Pack Installed: 1
I've been getting different errors recently, but this is the first of its kind. I'm trying to set up a pseudo-differential signal on a Stratix III.
Any advice as to where I can find info on this error? I've been looking, but haven't found anything.
unfortunately, most internal errors are hard to debug without Altera's help. i recommend creating a small project that exhibits this problem and attaching it to a Service Request
note that 9.1 is getting to be a bit old, support may be limited
Most internal errors can be removed by deleting "db and incremental db",try to delete and see if it works.
Thanks Jai Shree!! I usually restart Quartus and it works!!
