Programmable Devices
21611 Discussions
Quartus Prime Lite - Difficulties with simulation
Hi all,
I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PLL generated through the wizard, and watch the clock and locked outputs.
As you can see from the simulation the lock remains low, and the clock output is in an unknown state. I don't see any warnings or errors in modelsim.
Any help would be greatly appreciated.
library ieee; use ieee.std_logic_1164.all; entity top is port ( inclk0 : in std_logic; c0 : out std_logic; locked : out std_logic ); end entity; architecture rtl of top is component pll0 PORT ( inclk0 : IN STD_LOGIC := '0'; c0 : OUT STD_LOGIC ; locked : OUT STD_LOGIC ); end component; begin pll0_inst : pll0 PORT MAP ( inclk0 => inclk0, c0 => c0, locked => locked ); end rtl;
https://alteraforum.com/forum/attachment.php?attachmentid=14807&stc=1
Can you even synthesize the design in Quartus? Perhaps the PLL IP was not generated correctly or you didn't generate simulation model files. Did you make sure that the simulation model is getting compiled in ModelSim?
Are you using testbench?
Can you attach the transcript of Modelsim?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
I got past the PLL issue
My problem now is with the modular adc simulation. I used the wizard to configure the ADC, include the .qip and .sip files in the project as suggested by the prompt. When I go to simulate I get this:
vcom -reportprogress 300 -work work /home/swinchen/quartus/robot_board_test/robot_board_tb.vhd# Model Technology ModelSim - Intel FPGA Edition vcom 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Feb 09,2018# vcom -reportprogress 300 -work work /home/swinchen/quartus/robot_board_test/robot_board_tb.vhd # -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Loading package NUMERIC_STD# -- Compiling entity robot_board_tb# -- Compiling architecture rtl of robot_board_tb# End time: 10:25:41 on Feb 09,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0 vsim work.robot_board_tb# vsim work.robot_board_tb # Start time: 10:25:50 on Feb 09,2018# Loading std.standard# Loading std.textio(body)# Loading ieee.std_logic_1164(body)# Loading ieee.numeric_std(body)# Loading work.robot_board_tb(rtl)# Loading altera_mf.altera_mf_components# Loading work.robot_board(rtl)# Loading ieee.std_logic_arith(body)# Loading ieee.std_logic_unsigned(body)# Loading altera_mf.altera_common_conversion(body)# Loading altera_mf.altera_device_families(body)# Loading altera_mf.altsyncram(translated)# Loading work.pll(syn)# Loading altera_mf.mf_pllpack(body)# Loading altera_mf.altpll(behavior)# Loading altera_mf.mf_cycloneiii_pll(vital_pll)# Loading altera_mf.mf_cda_mn_cntr(behave)# Loading altera_mf.mf_cda_scale_cntr(behave)# Loading work.adc_controller(rtl)# Loading work.adc_core(rtl)# ** Warning: (vsim-3473) Component instance "modular_adc_0 : adc_core_modular_adc_0" is not bound.# Time: 0 ps Iteration: 0 Instance: /robot_board_tb/dut/adc_inst File: /home/swinchen/quartus/robot_board_test/adc_core/simulation/adc_core.vhd# Loading work.slave_spi_interface(rtl)# ** Warning: Design size of 17430 statements exceeds ModelSim-Intel FPGA Starter Edition recommended capacity.# Expect performance to be adversely affected.# ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/command_ready, and its initial value is not used.# Therefore, simulation behavior may occur that is not in compliance with# the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/command_ready.# ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_valid, and its initial value is not used.# Therefore, simulation behavior may occur that is not in compliance with# the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_en.# ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_channel(4), and its initial value is not used.# Therefore, simulation behavior may occur that is not in compliance with# the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_chsel(4).# ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_channel(3 downto 0), and its initial value is not used.# Therefore, simulation behavior may occur that is not in compliance with# the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_chsel(3 downto 0).# ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_data, and its initial value is not used.# Therefore, simulation behavior may occur that is not in compliance with# the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_data.
I am not sure how to get rid of the # ** Warning: (vsim-3473) Component instance "modular_adc_0 : adc_core_modular_adc_0" is not bound..
Any suggestions?
I tried including the "modular_adc_0" library and get this:
# Loading modular_adc_0.adc_core_modular_adc_0 # ** Error: (vsim-3033) /home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v(26): Instantiation of 'adc_core_modular_adc_0_control_internal' failed. The design unit was not found. # Time: 0 ps Iteration: 0 Instance: /robot_board_tb/dut/adc_inst/modular_adc_0 File: /home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v # Searched libraries: # /home/swinchen/quartus/robot_board_test/simulation/modelsim/robot_board_test_iputf_libs/modular_adc_0 # /home/swinchen/quartus/robot_board_test/simulation/modelsim/rtl_work # Loading work.slave_spi_interface(rtl) # Error loading design # End time: 10:57:09 on Feb 09,2018, Elapsed time: 0:00:00 # Errors: 1, Warnings: 0
May be because of compilation order,component interface declaration.
If you compile each file separately and you have to compile from the bottom up.
or
Use script to setup environment which is generated during design.
Threads addressing same issue
http://www.alteraforum.com/forum/showthread.php?t=36720
https://www.alteraforum.com/forum/showthread.php?t=53077
Anand Raj Shankar
Those threads do not appear to have solutions.
What is the name of the script that is generated during the design?
I believe modelsim is running this script (simulation/modelsim/robot_board_test_run_msim_rtl_vhdl.do):
transcript on if ! { file mkdir robot_board_test_iputf_libs } if {} { vdel -lib rtl_work -all } vlib rtl_work vmap work rtl_work # ##### Libraries for IPUTF cores vlib robot_board_test_iputf_libs/control_internal vmap control_internal ./robot_board_test_iputf_libs/control_internal vlib robot_board_test_iputf_libs/modular_adc_0 vmap modular_adc_0 ./robot_board_test_iputf_libs/modular_adc_0 # ##### End libraries for IPUTF cores # ##### MIF file copy and HDL compilation commands for IPUTF cores vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_avrg_fifo.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_fsm.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/chsel_code_converter_sw_to_hw.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_primitive_wrapper.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_top_wrapper.v" -work control_internal vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v" -work modular_adc_0 vcom "/home/swinchen/quartus/robot_board_test/adc_core/simulation/adc_core.vhd" vlog -vlog01compat -work work +incdir+/home/swinchen/quartus/robot_board_test/db {/home/swinchen/quartus/robot_board_test/db/pll_altpll.v} vcom -93 -work work {/home/swinchen/quartus/robot_board_test/slave_spi_interface.vhd} vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board.vhd} vcom -93 -work work {/home/swinchen/quartus/robot_board_test/adc_controller.vhd} vcom -93 -work work {/home/swinchen/quartus/robot_board_test/pll.vhd} vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board_tb.vhd} vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L fiftyfivenm_ver -L rtl_work -L work -L control_internal -L modular_adc_0 -voptargs="+acc" robot_board_tb do /home/swinchen/quartus/robot_board_test/adc_core/simulation/mentor/msim_setup.tcl
Are you saying that the msim_setup.tcl should be executed first?
--- Quote Start ---
--- Quote End ---
Yes,
DO you have license?
The warning may be generated because of license.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)https://www.alteraforum.com/forum/attachment.php?attachmentid=14820
What would I need for a license? I am using Quartus Prime Lite 17.1. My design is relatively small and I don't get any warnings/errors about exceeding the 10,000 LOC limit.
- Sam
It's not related to license.
1.Use the msim_setup.tcl for simulation which help us to load all the necessary libraries.
2.And also follow the steps given in msim_setup.tcl which will eliminate the warning.
The image which i have attached previously,There i tried to loaded the libraries manually which generated the warning.
Now i have simulated the same project using script which eliminated the warning.
So this warning may be related to libraries and compilation order.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
https://www.alteraforum.com/forum/attachment.php?attachmentid=14839
I think I'm having the same problem with ALTPLL RTL simulation. I have to believe this is something simple, but I'm not getting the PLL to put out a clock.
Testbench code:
`timescale 1ns / 1ps
module TB_1();
// Inputs
reg ClkIN;
reg ResetN;
wire [3:0] SignalOut;
testpll testpll(
.ClkIN(ClkIN),
.ResetN(ResetN),
.SignalOut(SignalOut)
initial begin
ClkIN = 1'b0;
# 5 ClkIN = 1'b1;
forever
begin
//Create a 25MHz clock
# 20 ClkIN = !ClkIN;
end
end
initial begin
$display($time, " << Starting Simulation >> ");
# 1 ResetN = 1'b1;
//Apply Reset twice
# 150 ResetN = 1'b0;
# 1500 ResetN = 1'b1;
# 1500 ResetN = 1'b0;
# 1000;
$display($time, "<< Simulation Complete >>");
// $stop;
end
endmodule
No errors or warnings in modelsim. I have attached a couple of screencaps of the waveforms. There should be plenty of time to lock.
FPGA code:
module testpll (
ClkIN,
ResetN,
SignalOut );
input ClkIN;
input ResetN;
output [3:0] SignalOut;
reg [3:0] SignalOut;
wire SysClk;
always @ (posedge SysClk or negedge ResetN)
begin
if (!ResetN)
begin
SignalOut <= 0;
end
else begin
SignalOut <= SignalOut+1; //simple 4-bit free-running counter w/ ACLR
end
end //end always
* PLL block instantiation. Take in 25 MHz clock and generate internal 135 MHz clock
Imelda_PLL Imelda_PLL(
.areset ( !ResetN ),
.inclk0 ( ClkIN ),
.c0 ( SysClk ),
.locked ()
&nbsp;);
endmodule
The PLL is from the project that I originally had the issue with, so I cut it down to this simple example. The PLL simply takes in 25 MHz and cranks it up to 135 MHz. I can zip the folder and send it if you like.
This is targeted to a 10CL006-8 in TQFP. Quartus Prime Lite Edition V17.1.1 Build 593 12/11/2017
Any thoughts or suggestions? Until I have a clock it's kinda tough to do much simulation.
Thanks much
Chip Brownhttps://alteraforum.com/forum/attachment.php?attachmentid=14908&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14909&stc=1
When you generated the ALTPLL core, did you use the reset pin and what is the setting for the reset ( PLLs can be reset internally or via external reset pin). If you have used reset internally, the reset logic will be added internally and PLL will auto-reset itself on Power-on. If using external reset , you will have to provide the reset controls as you've already done. During simulations, have you also included the device specific simulation libraries for the PLLs?
- Abr
I have tried the PLL with and without the "Enable self-reset on loss lock" check. No difference. I tried adding a pfdena input tied to 1'b1 and !ResetN - no difference.
What seems most strange to me is that the simulation shows the c0 output in the HiZ state. I don't understand what's in that block, but I would not expect it to be HiZ ever.
I will submit a support case and see if I can send the testpll folder for you to look at. Service request# 11384121
This is the output I get from modelsim:
# Reading C:/intelFPGA_lite/17.1/modelsim_ase/tcl/vsim/pref.tcl# do testpll_run_msim_rtl_verilog.do# if {[file exists rtl_work]} {# vdel -lib rtl_work -all# }# vlib rtl_work# vmap work rtl_work# Model Technology ModelSim - Intel FPGA Edition vmap 10.5b Lib Mapping Utility 2016.10 Oct 5 2016# vmap work rtl_work # Copying C:/intelFPGA_lite/17.1/modelsim_ase/win32aloem/../modelsim.ini to modelsim.ini# Modifying modelsim.ini# # vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source/testpll_20180302.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/source/testpll_20180302.v # -- Compiling module testpll# # Top level modules:# testpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL/testpll_altpll.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/ALTPLL/testpll_altpll.v # -- Compiling module testpll_altpll# # Top level modules:# testpll_altpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db/testpll_altpll_altpll.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/db/testpll_altpll_altpll.v # -- Compiling module testpll_altpll_altpll# # Top level modules:# testpll_altpll_altpll# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# # vlog -vlog01compat -work work +incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source {C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source/TB_1_20180301.v}# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016# Start time: 10:25:41 on Mar 02,2018# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source" C:/projects/Imelda/FPGA/Imelda_Altera_10CL006_testpll/simulation/source/TB_1_20180301.v # -- Compiling module TB_1# # Top level modules:# TB_1# End time: 10:25:41 on Mar 02,2018, Elapsed time: 0:00:00# Errors: 0, Warnings: 0# # vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclone10lp_ver -L rtl_work -L work -voptargs="+acc" TB_1# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclone10lp_ver -L rtl_work -L work -voptargs=""+acc"" TB_1 # Start time: 10:25:41 on Mar 02,2018# Loading work.TB_1# Loading work.testpll# Loading work.testpll_altpll# Loading altera_mf_ver.altpll# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.pll_iobuf# # add wave *# view structure# .main_pane.structure.interior.cs.body.struct# view signals# .main_pane.objects.interior.cs.body.tree# run -all# 0 << Starting Simulation >> # 5651<< Simulation Complete >>
restart -f
add wave -position end sim:/TB_1/testpll/testPLL/areset
add wave -position end sim:/TB_1/testpll/testPLL/pfdena
add wave -position end sim:/TB_1/testpll/testPLL/inclk0
add wave -position end sim:/TB_1/testpll/testPLL/locked
add wave -position end sim:/TB_1/testpll/testPLL/c0
https://alteraforum.com/forum/attachment.php?attachmentid=14913&stc=1
Hopefully this is something simple I've overlooked. If so, I'll be sure to post exactly what it is for others to learn from.
I got the similar design logic to work on ModelSim Intel edition and Quartus 17.1 (with latest updates) . Here's the code ;
module plltest ( Clock, Reset, Locked, CountOut ); input Clock; input Reset; output Locked; output CountOut; wire CountOut; wire Locked; reg Count; wire PLL_clock; pll_1 counter_pll ( .refclk (Clock), .rst (~Reset), .locked (Locked), .outclk_0(PLL_clock) ); always@(posedge PLL_clock or negedge Reset) begin if (~Reset) begin Count <= 4'b0000; end else begin if(Locked) begin Count <= Count + 4'b0001; end else begin Count <= 4'b0000; end end end //always assign CountOut = Count; endmodule
The PLL locked at the input clock, Locked port went high and the counter output was generated. I've included the QAR file, you could extract it and check it out. The device used is Cyclone 5 GX, so the PLL used is Altera_PLL. I'll be generating one more with the Cyclone10LP device and the ALTPLL function as well.
- Abr
Just tried with the ALTPLL function and the output clock is not being generated. This is definitely a sim model issue and needs to be fixed by Altera. Thanks for pointing it out.
-Abr
Thanks very much for taking the time to verify that it doesn't work! It would have been simple to have left it without trying the 10 LP and ALTPLL, and I would have spent a bunch of time fruitlessly trying to replicate your results in my environment. I'm glad to know that I'm not (completely) crazy or a (complete) moron. :)
Any suggestions for tricking a testbench into generating the PLL output clock without changing the synthesized code? I suppose I could just create a version with an input clock to the FPGA that replaces the PLL output for functional testing, but the timing would likely be totally whacked.
And please advise on the estimated timeframe for the simulator fix. I know that's asking a lot.
Thanks again!
--- Quote Start ---
Thanks again!
--- Quote End ---
Yes we acknowledged this bug/issue and has been reported to the engineering team.
however you can run cyclone 10 lp altpll vhdl simulation model in quartus v17.0 and v17.1.
it works fine
Anand Raj Shankar
Please check the below link the problem has been addressed.
https://www.altera.com/support/suppo...-lp-pll-i.html
Anand Raj Shankar
