21602 Discussions
Questions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems:
1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use "aocl program acl0 bin/fft2d.aocx" to test the progrom, i got the following errors:
aocl program: Running reprogram from /home/storm/altera/14.0/hld/board/de5net_network/linux64/libexec
Unable to open the device acl0.
aocl program: Program failed.
2.in the "driver installation " section, when i use "aocl install " or "./make_all " to install the driver, i got the following errors:
aocl install: Running install from /home/storm/altera/14.0/hld/board/de5net_network/linux64/libexec
Using kernel source files from /usr/src/linux-headers-3.16.0-30-generic
make: Entering directory `/usr/src/linux-headers-3.16.0-30-generic'
CC [M] /tmp/opencl_driver_yH5TgN/aclpci_queue.o
CC [M] /tmp/opencl_driver_yH5TgN/aclpci.o
/tmp/opencl_driver_yH5TgN/aclpci.c:61:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘probe’
static int __devinit probe(struct pci_dev *dev, const struct pci_device_id *id);
/tmp/opencl_driver_yH5TgN/aclpci.c:62:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘init_chrdev’
static int __devinit init_chrdev (struct aclpci_dev *aclpci);
/tmp/opencl_driver_yH5TgN/aclpci.c:63:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘remove’
static void __devexit remove(struct pci_dev *dev);
/tmp/opencl_driver_yH5TgN/aclpci.c:65:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘scan_bars’
static int __devinit scan_bars(struct aclpci_dev *aclpci, struct pci_dev *dev);
/tmp/opencl_driver_yH5TgN/aclpci.c:66:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘map_bars’
static int __devinit map_bars(struct aclpci_dev *aclpci, struct pci_dev *dev);
/tmp/opencl_driver_yH5TgN/aclpci.c:82:12: error: ‘probe’ undeclared here (not in a function)
.probe = probe,
/tmp/opencl_driver_yH5TgN/aclpci.c:83:13: error: ‘remove’ undeclared here (not in a function)
.remove = remove,
/tmp/opencl_driver_yH5TgN/aclpci.c:115:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘init_chrdev’
static int __devinit init_chrdev (struct aclpci_dev *aclpci) {
/tmp/opencl_driver_yH5TgN/aclpci.c:489:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘probe’
static int __devinit probe(struct pci_dev *dev, const struct pci_device_id *id) {
/tmp/opencl_driver_yH5TgN/aclpci.c:571:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘scan_bars’
/tmp/opencl_driver_yH5TgN/aclpci.c:592:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘map_bars’
/tmp/opencl_driver_yH5TgN/aclpci.c:640:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘remove’
static void __devexit remove(struct pci_dev *dev) {
/tmp/opencl_driver_yH5TgN/aclpci.c:628:13: warning: ‘free_bars’ defined but not used [-Wunused-function]
static void free_bars(struct aclpci_dev *aclpci, struct pci_dev *dev) {
/tmp/opencl_driver_yH5TgN/aclpci.c:103:21: warning: ‘aclpci_get_free’ defined but not used [-Wunused-function]
static unsigned int aclpci_get_free(void)
/tmp/opencl_driver_yH5TgN/aclpci.c:449:24: warning: ‘find_upstream_dev’ defined but not used [-Wunused-function]
static struct pci_dev* find_upstream_dev (struct pci_dev *dev) {
make[1]: *** [/tmp/opencl_driver_yH5TgN/aclpci.o] Error 1
make: *** [_module_/tmp/opencl_driver_yH5TgN] Error 2
make: Leaving directory `/usr/src/linux-headers-3.16.0-30-generic'
cp: cannot stat ‘./aclpci_drv.ko’: No such file or directory
cp: cannot create regular file ‘/etc/sysconfig/modules/aclpci.modules’: No such file or directory
chmod: cannot access ‘/etc/sysconfig/modules/aclpci.modules’: No such file or directory
modprobe: FATAL: Module aclpci_drv not found.
The Operating system is Ubuntu and the board is De5-NET FPGA.
I appreciate if anyone can help me.
Jiawen
I also meet the same problem. May I know if you have solved that?
The kernel is too new. Downgrading your kernel will solve the errors shown above.
Hi Chris,
I didn't solve this problem yet. After you downgrade the kernel, did you install it successfully?
I use the 14.04 of Ubuntu. Should I downgrade it into 12.0 of Ubuntu?
Jiawen
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
Hi Chris,
Jiawen
--- Quote End ---
I am not using Ubuntu for the fpga board. But you can check the kernel version to decide which version to roll back to. The kernel should include a set of macros (such as __devint).
I would not roll-back your kernel. That seems like too much effort ;)
There are a few changes one can make to get this to work in 14.04LTS Trusty Ubuntu. So far I've had no problems but I do need to test more.
Firstly, the aocl install command wont work. You need to go manual
navigate to altera/15.0/hld/board/terasic/de5net/linux64/driver
Modify the file aclpci_cmd.c removing any of the __ macros before the function declarations. Also comment out lines 442 to 434
if (dev->aer_firmware_first) {
return -EIO;
install the headers for your current kernel (apt-get install linux-kernel-headers)
change the make_all.sh file so the path points to your new kernel headers directory (something like /usr/src/linux-headers-3.16.0-50-generic)
run make_all.sh - this will result in the file aclpci_drv.ko
Copy this file to /lib/modules/3.16.0-50-generic/misc (replacing 3.16.0-50-generic with your current kernel)
Run modprobe aclpci_drv and then check dmesg for any problems.
Job done! So far this works for me in terms of checking for programs that are flashed to the memory. I need to perform more testing which I will
--- Quote Start ---
return -EIO;
--- Quote End ---
Hi oni,
Thank you so much for you reply! I have followed every step and then run make_all.sh, but I got the following error messages and didn't result in the file ecliptic_drv.ko:
CC [M] /home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.o
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:61:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘probe’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:62:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘init_chrdev’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:63:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘remove’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:65:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘scan_bars’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:66:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘map_bars’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:82:12: error: ‘probe’ undeclared here (not in a function)
.probe = probe,
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:83:13: error: ‘remove’ undeclared here (not in a function)
.remove = remove,
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:115:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘init_chrdev’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:489:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘probe’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:571:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘scan_bars’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:592:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘map_bars’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:640:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘remove’
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:628:13: warning: ‘free_bars’ defined but not used [-Wunused-function]
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:103:21: warning: ‘aclpci_get_free’ defined but not used [-Wunused-function]
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.c:449:24: warning: ‘find_upstream_dev’ defined but not used [-Wunused-function]
make[1]: *** [/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci.o] Error 1
make: *** [_module_/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver] Error 2
I hope I could get your reply and deal with this problem.
Jiawen
I should probably post a patch file at some point, but it is the __devinit, __devexit and other such macros that are causing issues as they are not defined in the altera lib and therefore I assume they are defined in the older kernel headers. Remove all these and try again.
Cheers
B
--- Quote Start ---
Cheers
--- Quote End ---
Thank you so much for you reply soon! I solved the problem mentioned above! But I got a new error message as following:
CC [M] /home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.o
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.c: In function ‘aclpci_exec_cmd’:
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.c:83:12: error: void value not ignored as it ought to be
result = pci_restore_state(aclpci->pci_dev);
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.c: In function ‘get_aer_uerr_mask_reg’:
/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.c:438:10: error: ‘struct pci_dev’ has no member named ‘aer_firmware_first’
make[1]: *** [/home/storm/altera/15.0/hld/board/de5net_network/linux64/driver/aclpci_cmd.o] Error 1
It that the same problem above?
I am looking for your reply online and hope I would deal with it.
Thank you,
Jiawen
--- Quote Start ---
Hi B,
I have deal with the problem successfully!!
Thank you so much for you reply and help!
Best wishes,
Jiawen
--- Quote End ---
Np! I think I just commented out these lines as they seemed to me to be an edge case, though this might come back to bite me later on :S
Cheers
B
Hi B,
After everything was setting and compile the test code of OpenCl successfully, when I tried to run the file, I got the following errors:
storm@storm:~/altera/15.0/hld/board/de5net_network/tests/matrix_mult/bin$ ./matrix_mult
./matrix_mult: error while loading shared libraries: libalteracl.so: cannot open shared object file: No such file or directory
Do you know what is the problem? I have followed the manual step by step to set up.
Thank you,
Jiawen
--- Quote Start ---
Hi B,
Best wishes,
Jiawen
--- Quote End ---
Hi Jiawen,
For the first question, the unable to open device acl0. Can I know if you also solve that? Thanks
--- Quote Start ---
Hi Jiawen,
--- Quote End ---
After I installed the drivers successfully, I still had this problem and didn't deal with it. The errors are as followings:
root@storm:/home/storm/altera/14.0/hld/board/de5net_network/tests/fft2d# aocl program acl0 bin/fft2d.aocx
I appreciate someone can give me any suggestion.
Best wishes,
Jiawen
--- Quote Start ---
Best wishes,
Jiawen
--- Quote End ---
Hi Jiawen,
Did you try the aocl diagnose to make sure the system can find the fpga device currently?
--- Quote Start ---
Hi Jiawen,
--- Quote End ---
I tried aocl diagnose. But it didn't detect any FPGA devices. Do you know what's the problem?
I am chinese . So my english is poor and i need the same problem which you solved ? can you help me solve this problem?
thank you!
--- Quote Start ---
.probe = probe,
.remove = remove,
Jiawen
--- Quote End ---
I need the same problem.Please help me! Thank you!
When i do aocl install,I need some problem.
It seems that Ubuntu cannot support the OpenCL well. Please have a try to use Red Hat Ehterprise 64-bit Linux instead. Altera recommand to use this one on working with OpenCl.
I have an easier way of getting this running which works on the latest Centos-7 and I presume will also work on Ubuntu and other distributions.
First navigate to the linux/driver of the BSP.
Firstly edit aclpci.c: At the top of the file add the lines #define __devinit # define __devexit
Secondly edit aclpci_cmd.c: On line 83 remove the assignment Change result = pci_restore_state(aclpci->pci_dev); to pci_restore_state(aclpci->pci_dev);On lines 438-440 comment out (or delete) the statement if (dev->aer_firmware_first) { return -EIO; }
You should now be able to run "aocl install" successfully.
