21610 Discussions
RTL, Post synthesis and Gate Level Simulation
Hi. I can't find the clear differences on the topic above.
From what i understand,
RTL : Functional simulation is working on any technolgy
Post Synthesis: Functional Simulation on targeted device of specific technology
Gate Level: Timing simulation that includes timing info after fitting process
Am i right? Pls give clear differences between each another.
Besides, in Simulating Designs with EDA Tools.pdf, it mentions abt Post Synthesis and gate level simulation. However, in quartus ii, i can't find the post synthesis simulation. Is the rtl simulation means post synthesis simulation? Any idea?
thanks
all the answer can be found in Simulating Designs with EDA Tools.pdf. thanks
RTL simulation is the simulation of the code pre-synthesis. Its like behavioural simulation. With good design practice 99 times out of 100 the RTL simulation should match the gate level simulation.
Hi, I'm having touble with the PowerPlay tool in Quartus II. I'm a beginner to this software. I have generated the reqd vwf , vcd and saf files but when i run the PowerPlaytool i keep getting an error saying ' Successful run of Assembler reqd' . I the run the fitter and assembler from the processing/start menu , but i still receive the same error. I would be greatful if you could help me .
Thank You.
