21615 Discussions
Regarding UL, CSA, VDE certification standards.
NarayanMarkandeya
Please share the UL, CSA and VDE certification number for the below part which is useful for our project.
EN6337QI
10M50DAF484C8G
Awaiting your favorable response ASAP.
Thanks & Regards,
Narayan Markandeya
ak6dn
Valued Contributor III
Those are individual component part numbers.
UL et al standards are not applicable at the component level.
YOU need to design these parts into a product and then YOU get certification for your product from UL et al.
NarayanMarkandeya
Thanks for updates, Can you please whether VDE and CSA standards are applicable or not? if applicable please share certificate numbers.
Also inform if other standards are applicable and share the certification numbers.
NarayanMarkandeya
Hi, Thanks for updates, Can you please check whether VDE and CSA standards are applicable or not? if applicable please share certificate numbers. Also inform if other standards are applicable and share the certification numbers.
