I have created a combined hardware and software image for both the factory design and the application image and programmed them to the EPCS. However when I reconfiguration in NIOSII at the application image address(0x300000 in EPCS), the factory image is always loaded.
the problem in sum is that the reconfiguration's hw_offset is not used the in EPCS process. I also check with all the Altera Forum for this issure. but nothing can help for me. so,I think there are some reason for the reconfiguration offset problems ? does anyone has the same situation?Link Copied
Have you created a custom bootloader to allow you to boot the application image? The default bootloader will not do this. You can program the FPGA with the correct fpga image but the default EPCS bootloader will always look at the factory software image.
Jake- Mark as New
Hi jakobjones,
I'm trying to do the same thing. Do you have a custom bootloader example for this case? Thanks.- Mark as New
Hi jakobjones,
I am trying to do the similar... you would think an example would be available from Altera... Thanks.- Mark as New
Have a look at this thread:
http://www.alteraforum.com/forum/showthread.php?t=20623&referrerid=2226 I have posted a bootloader there. However, it was hand tweaked for Stratix II. The other thread you'll want to look at is: http://www.alteraforum.com/forum/showthread.php?t=23447&referrerid=2226 Jake- Mark as New
If someone has a Cyclone III custom bootloader example for this case please help.
--- Quote Start --- Have you created a custom bootloader to allow you to boot the application image? The default bootloader will not do this. You can program the FPGA with the correct fpga image but the default EPCS bootloader will always look at the factory software image. Jake --- Quote End --- thanks Jak, I mean that the remote config can't load the application FPGA image, I make a second FPGA(.sof) image in the EPCS, (The LED will show it running).but it shows that the second FPGA(.sof) image failed to load.
