21591 Discussions
Reset circuit / Cyclone III
I am new designer with Altera Devices and not familiar with it so I would appreciate advices from experienced users, concerning Reset circuit.
I am used to put reset circuit for µP and Xilinx devices, that holds low the Configuration Reset pin (nCONFIG here), while all the power supplies are not settled.
I had a look to a couple of Altera boards schematics and this pin is always tied to VCCIO via a 10k pull-up.
Is it still a good practice to use a Voltage supervisor reset circuit that will hold low nCONFIG and release it 200 ms after ?
Any bad experience in doing (or not) this?
Another question: what is the exact POR voltage threshold for VCCINT/VCCIO or where can I found it?
Thank you for your answers.
> Any reply ?
