Ankündigungen
21615 Diskussionen
SDF generation for Cyclone V on Quartus 19.1 Standard Edition
anm
Neuer Beitragender I
2.057Aufrufe
I have compiled a design on a Cyclone V FPGA using the Quartus 19.1 Standard Edition.
I want to generate an SDF file to perform Post-Place and Route simulation.
I have tried all of the Quartus settings but didn't have any success thus far. I also found some posts in the forum (like this one https://forums.intel.com/s/question/0D50P00003yyGO5/cant-get-quartus-prime-standard-161-to-output-sdf) that seem to suggest that Quartus cannot generate and SDF file.
Is Quartus able to create an SDF file for my design? If so, how can I achieve that?
Thank you in advance for your responses.
Kind regards,
anm
1 Lösung
KhaiChein_Y_Intel
Mitarbeiter
2.048Aufrufe
Simulation using a post-fit timing netlist, testing functional and timing performance is supported only for the Arria® II GX/GZ,Cyclone® IV, MAX® II, MAX V, and Stratix® IV device families.
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-tp-simulation.pdf , Table 2, Page 5.
KhaiY
Lösung in ursprünglichem Beitrag anzeigen
3 Antworten
KhaiChein_Y_Intel
Mitarbeiter
2.049Aufrufe
KhaiY
anm
2.048Aufrufe
Hi KhaiY,
thank you very much for your answer. In the table I see that Gate-level timing simulation is not supported for the Cyclone-V.
Nevertheless, according to the table you mentioned, Gate-level functional simulation is supported for Cyclone-V.
Could you please verify that the post-fit netlist used for the Gate-level functional simulation is located in the ./simulation/modelsim folder under the name <design_name>.vo?
Thank you in advance for your response.
Kind regards,
anm
KhaiChein_Y_Intel
Mitarbeiter
2.045Aufrufe
Hi Anm,
The Verilog Output File is placed in the /<project directory>/simulation/<EDA simulation tool> directory.
KhaiY
Antworten
