Programmable Devices
公告
21615 讨论
SDRAM on DE0-nano board
名誉分销商 II
27,395 次查看
I am still not having any success writing and reading from the SDRAM on on the DE0-nano board from the FPGA.
I have built a system in qsys which includes a Nios II and SDRAM controller and downloaded it to the board.
The next thing I would like to do is write some code in VHDL or some program for the NIOS that reads and writes to the SDRAM.
How exactly does one achieve this? I believe the SDRAM controller takes care of all the control signals etc. so in order to write to it, I must specify the address in RAM first or just write data to the data pins connecting to it?
I am having problems understanding how this works. If anyone has more experience with this, I would appreciate your help.
Many thanks,
Paul
0 项奖励
23 回复数
名誉分销商 II
22,317 次查看
Hi Paul,
Here's a design that creates a Qsys system containing a JTAG master and an Altera SDRAM Controller. I tested it under Quartus 12.1, 13.0, 13.1, and 14.0. Unzip the file into c:/temp/ and follow the instructions in the readme.txt file, i.e.,
DE0-nano 'sdram' design ----------------------- 8/19/2014 D. W. Hawkins (dwh@ovro.caltech.edu) To synthesize the design, perform the following steps; 1) Unzip de0_nano_sdram.zip, eg., into your c:/temp directory. 2) Start Quartus II This script was tested with versions 12.1, 13.0, 13.1, and 14.0. The SDRAM controller parameters changed slightly after Quartus 12.1, see scripts/qsys_system.tcl. 3) Select the Tcl console. If the Tcl console is not visible, use the menu option View->Utility Windows->Tcl Console 4) Use the Tcl console to change into the DE0-nano source folder. tcl> cd c:/temp/de0_nano_sdram 5) Issue the following command to source and run the synthesis script tcl> source scripts/synth.tcl The console will output the script progress. For example, under Quartus II 12.1sp1 (on Windows XP) the output was: Synthesizing the DE0-nano 'sdram' design ---------------------------------------- - Quartus Version 12.1 Build 243 01/31/2013 Service Pack 1 SJ Full Version - Creating the Quartus work directory * C:/temp/de0_nano_sdram/qwork - Create the project 'de0_nano' * create a new de0_nano project - Applying constraints - Creating the VHDL files list - Generate the Qsys system * creating the Qsys file in the work directory * Tcl-to-Qsys generation for Quartus version 12.1 * generating the Qsys system (please wait) - Processing the design - Processing completed and under Quartus II 14.0 (on Windows 7) the output was: Synthesizing the DE0-nano 'sdram' design ---------------------------------------- - Quartus Version 14.0.0 Build 200 06/17/2014 SJ Full Version - Creating the Quartus work directory * C:/Temp/de0_nano_sdram/qwork - Create the project 'de0_nano' * create a new de0_nano project - Applying constraints - Creating the VHDL files list - Generate the Qsys system * creating the Qsys file in the work directory * Tcl-to-Qsys generation for Quartus version 14.0 * generating the Qsys system (please wait) - Processing the design - Processing completed This design passes TimeQuest analysis, with no unconstrained paths. NOTE: The Altera SDRAM controller does not create an SDC constraints file. See scripts/de0_nano.sdc for appropriate SDRAM constraints. At this point, the design is ready to test in hardware. The Qsys system instantiated in the top-level design was created by the synthesis script (see scripts/synth.tcl for details). You can inspect the Qsys system by starting Qsys via Tools->Qsys, then open the file qsys_system.qsys, and look at the Qsys system settings, eg., the SDRAM controller parameters. If you repeat this sequence under Quartus 12.1, 13.0, 13.1 or 14.0, you will see that although the Qsys GUI changes slightly, the Qsys SDRAM controller parameters remain correct. 6) Program your board a) Plug the DE0-nano into your computer. b) Open the Quartus programmer. In the main Quartus GUI, the programmer has a symbol on the top menu bar that looks like a cable going into a diamond, If you hover your mouse over it, the tooltip is "Programmer" c) At the top-level of the programmer GUI, there is a button that says "Hardware Setup", to the right of that should be the text "USB-Blaster ". If you do not see the USB-Blaster text, click on the "Hardware Setup" program and see if its listed there, if it is, select it. d) In the programmer GUI, you should see the file de0_nano.osf ready to be programmed into the single device in the JTAG chain. Press the "Start" button to download to the board. e) The LEDs on the DE0-nano will then start counting. This indicates that the 100MHz PLL is operating correctly. f) Start SystemConsole The GUI directions for starting SystemConsole change depending on the Quartus version. Under 12.1 you have to start Qsys and select it via Tools->System Console, under newer versions of Quartus, the main GUI Tools menu can be used, eg., under Quartus 14.0 use Tools->System Debugging Tools->System Console. Start SystemConsole and source the JTAG commands script, eg., % source c:/temp/de0_nano_sdram/scripts/jtag_cmds.tcl Then run the (simple) SRAM test % sdram_test Writing to 256 SDRAM locations Reading from 256 SDRAM locations SDRAM write/read checks passed! You can pass the number of locations to test, eg., % sdram_test 0x1000 Writing to 4096 SDRAM locations Reading from 4096 SDRAM locations SDRAM write/read checks passed! This design and the JTAG tests is extremely basic and simply shows that the memory works. A more exhaustive memory test would create a Qsys system with a pattern generator, DMA controller, and pattern checker, and then use that to send burst data to and from the SDRAM controller. Enjoy!
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Dave,
When I try to source synth.tcl , I receive error :
error: can't find package ::quartus:: project while executing "package require ::quartus:: project" (file "synth.tcl" line 34) invoked from within "source synth.tcl"
0 项奖励
名誉分销商 II
22,317 次查看
Hi Paul,
--- Quote Start ---
--- Quote End ---
Which Tcl console did you try to run the script from? It should be run from the Quartus Tcl console, not SystemConsole.
Note that the instructions indicate you should cd to the top-level of the project folder and issue "source scripts/synth.tcl", i.e., you should not have changed directory to the scripts folder and issued "source synth.tcl". The script uses the location you source it from to determine relative paths.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Dave,
I have now added an SDRAM controller to the qsys design from the jtag-to-avalon-mm example, gave it address 0x0 and assigned all the appropriate pins for the DE0-nano SDRAM with pin-planner.
In the jtag_cmds_sc.tcl script , I have added extra code to "talk" to the external SDRAM on the DE0-nano as follows :
proc sdram_write {offset data} { global jtag if {!} { jtag_open } set addr master_write_32 $jtag(master) $addr $data return } proc sdram_read {offset} { global jtag if {!} { jtag_open } set addr return }
When I then try to write from the tcl console with command "sdram_write 0 0x12345" for example and read it back with "sdram_read 0" , I am only reading 0x00000045, hence only the lower 8 bits seem to be written everytime. What would be the issue here. Is it something with the tcl script or my SDRAM controller settings?
In my SDRAM controller settings , the data width is set to 16 bits , chip select :1 , banks: 4 Under address width , Row : 13 , Column : 9
Paul
0 项奖励
名誉分销商 II
22,317 次查看
--- Quote Start ---
--- Quote End ---
But the SDRAM controller that Altera provides *DOES NOT* also come with timing constraints. Did you add them?
--- Quote Start ---
--- Quote End ---
Most likely SDRAM controller settings, though you could have a board or pin assignments error where the data mask bit for one lane is bad and is masking that byte lane.
Regarding the SDRAM controller settings, I recall changing the refresh rate to 7.8125us (half the default) and the power-on init delay to 200us (twice the default), to match the settings used in a couple of DE0-nano examples that I looked at.
Try the zip file I provided you, I know it works on my DE0-nano, so if it does not work on yours, that implies a hardware error where the mask bit is stuck.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Dave,
I have tested the example in the zip file and and it works fine, so there should be no problem with the hardware.
Going back to the SDRAM controller in Qsys, I have changed the refresh rate and power-on delay as you said but there is still something wrong.
Again, I am not sure if my settings in the memory profile tab are correct for the SDRAM on the DE0-nano. I have the data width set to 16 bits , chip select :1 , banks: 4 Under address width , Row : 13 and Column : 9.
The address assigned to the SDRAM controller is 0x10000000, therefore I have added the following to the tcl script. I am not sure if this is correct as I more or less replicated how you wrote it for the on-chip SRAM and changed the base address from 0x1000 to 0x10000000. The on-chip RAM also has a 32-bit data width instead of 16-bit so I'm wondering if my below code is acceptable? : Thanks
0 项奖励
名誉分销商 II
22,317 次查看
--- Quote Start ---
--- Quote End ---
Great! Its always useful to have minimal designs that prove your hardware works.
--- Quote Start ---
--- Quote End ---
In what respect? What error are you seeing?
What you have done seems reasonable. The Qsys system inserts width adapters, so the fact that your JTAG master is 32-bits and your SDRAM interface is 16-bits should not matter.
Whenever I see a problem in hardware, I first look at the problem using the Signal Tap II logic analyzer (which you can add to your FPGA design), and then I use a simulation to duplicate what I see in the hardware.
Try those tools and see how far you get. Ask questions when you get stuck.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
I'm not seeing an error. Just when I write to the SDRAM controller and try and read it back , the value is either 0xffffffff or just the last 8 bits are as expected.
To do a simulation, I need to create some testbench?
0 项奖励
名誉分销商 II
22,317 次查看
--- Quote Start ---
--- Quote End ---
I'd call that an error :)
You don't see this error with the example I gave you, right? Try comparing the top-level design. Perhaps you have made a simple mistake and not connected the ports on your Qsys instance correctly. Does the Quartus messages window have any weird looking messages?
--- Quote Start ---
--- Quote End ---
Yes, but first try tracing the RAM access using SignalTap II.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
I have been comparing the top-level designs and I still can't see what the problem is with mine. I have checked over and over again the pin assignments and qsys settings and compared them to yours and all seems to be ok. Below is my qsys system. The qsys_systm.v generated from that I use as my top level file. I just can't seem to write to the SDRAM. I must be missing something obvious.
https://www.alteraforum.com/forum/attachment.php?attachmentid=9316
0 项奖励
名誉分销商 II
22,317 次查看
Use Quartus to generate an archive file (.qar) and email it to me, and I'll take a look.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
--- Quote Start ---
I have checked over and over again the pin assignments and qsys settings ...
--- Quote End ---
The .qar file you sent generates warning messages about unconstrained clocks and paths and TimeQuest fails, so I think that is the root of your problem. Create an .SDC file for your project based on the example I provided.
This experience should help you understand that an HDL design consists of (at least);
1. The HDL design files.
2. The device constraints file (device type + pin assignments)
3. The timing constraints file (the .SDC file)
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Dave,
I am trying your BeMicro DDR3 example design but for the Bittware S5-PCIE-HQ board.
When I select the DDR3 controller in Qsys and under PHY settings, there is no option to "Enable Hard External Memory Interface" as explained and unable to set the "Rate on Avalon-MM interface" to "Full". The “maximum speed grade” that I am able select also is 4.
The RAM on the Bittware board is from MICRON and I see that there are different numbers on different chips – 4DE17D9QBJ , 3ZE77D9QBJ and 30E27D9QBJ so I am not sure which DDR device to select from the list on the right. You say to select MICRON MT41J64M16LA-15E. Would that be ok in this case?
When I compile the project and use your bemicro_cv.vhd as the top level Entity, I have to remove “ddr_status_local_init_done” , “ddr_status_local_cal_success” and “ddr_status_local_cal_fail” from the the Qsys component as my Qsys system did not generate these ports. Should this matter? I then receive errors on compilation like the following :
Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination Error (174068): Output buffer atom "qsys_system:u1|qsys_system_ddr3:ddr3|qsys_system_ddr3_p0:p0|qsys_system_ddr3_p0_memphy:umemphy|qsys_system_ddr3_p0_new_io_pads:uio_pads|qsys_system_ddr3_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_stratixv:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination
0 项奖励
名誉分销商 II
22,317 次查看
Hi Paul,
--- Quote Start ---
--- Quote End ---
Right, that is to be expected. Your particular device needs to support a Hard Memory Controller, otherwise that option will not be available. Given that its not available, your device does not have a hard memory controller, so skip that option.
--- Quote Start ---
--- Quote End ---
No. You have to find the correct Micron part number.
You can use Micron's package marking mapping tool to convert part labels to part numbers.
http://www.micron.com/products/support/fbga
D9QBJ = MT41K512M8RH-125:E
If Bittware have an example design that includes DDR3, open it and see what device parameters they have used, eg., to see if they have modified any of the defaultthe timing parameters.
--- Quote Start ---
--- Quote End ---
You probably did not click on the exports column to export them. If you synthesize the BeMicro-CV design and then use Qsys to open the qsys_system.qsys file, you will see the exported signals column.
--- Quote Start ---
--- Quote End ---
You have to run the pin constraints file created by the DDR3 IP core. In the BeMicro-CV design, this script is automatically run by the post-flow script. Since you appear to be synthesizing the qsys_system as the top-level design, then you need to run that script manually, via the Tools->Tcl script menu option.
Now that you have a sense of what needs to be done to create a DDR3 controller, you need to read the External Memory Interface handbook.
http://www.altera.com/literature/lit-external-memory-interface.jsp
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Dear Dave,
I am trying your script and this is happen in the console,
cd de0_nano_sdram
* /home/kanigoro/Desktop/de0_nano_sdram/qwork
2014.11.04.13:58:05 Error: Unrecognized switch 2
2014.11.04.13:58:05 Error: Invalid device family '"Cyclone' specified
Error: Qsys generation failed
Is there something that I am missing?...:D
Bayu Kanigoro
0 项奖励
名誉分销商 II
22,317 次查看
Hi Bayu Kanigoro,
--- Quote Start ---
--- Quote End ---
I don't think so. Post#2 shows the output from Quartus 14.0 Build 200, and it ran to completion.
I'll download the zip and run the script and confirm it works.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Bayu Kanigoro,
I just noticed the build folder on your machine ...
--- Quote Start ---
--- Quote End ---
which means you are running the script under Linux. Post#2 was run on a Windows 7 machine.
I recall seeing differences with Tcl scripts run under Windows vs Linux. I'll boot a Centos Virtual Machine and see if I can isolate the issue with the Tcl script. I have a good idea of where to look.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Hi Bayu Kanigoro,
Download the zip and try it now. It turns out that Linux did not like quotes in the exec arguments, so I changed them to ...
# synth.tcl set cmd "set quartus_version $qversion" lappend arg_list --cmd=$cmd # synth_qsys.tcl set device "Cyclone IV E" lappend arg_list --system-info=DEVICE_FAMILY=$device
and now it works fine.
Cheers,
Dave
0 项奖励
名誉分销商 II
22,317 次查看
Thanks Dave for the help. It works on Linux now..:)
Sorry for not to mention before that I was using Ubuntu Linux for running the script.
Bayu Kanigoro
0 项奖励
名誉分销商 II
22,034 次查看
--- Quote Start ---
--- Quote End ---
Great!
--- Quote Start ---
--- Quote End ---
No problem!
Cheers,
Dave
0 项奖励
回复
