This is killing me... I had a design just under way using SSS and lost the disk on my laptop. I actually had SSS running and modified it to parse commands so I know it works... When I load/build the verilog source for nios2_linux_3c120_125mhz_sys and generate a SSS with BSP on 9.1 sp1 I get the following:
InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Could not locate flash sector with MAC address. prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x08004000 WARNING : Unknown PHY found at PHY address 0x12 of MAC Group[0] WARNING : Please add PHY information to PHY profile INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established WARNING : PHY[0.0] - PHY not found in PHY profile INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 169.254.120.10 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) The PC is at 169.254.120.99 with a mask of 255.255.0.0 No ping, no telnet - any thoughts? It's likely I'm missing something dumb... Thanks - CLink Copied
Just a few thoughts:
- try with DHCP disabled - check if the activity led (I suppose your board has one) flashes when you ping the board - usually I have the SSS task created message and then the SSS listening: maybe the message order it's only a matter of tasks priorities, however I'd check this point. Cris
Topic Options
