21615 Discussions
Searching entire design
Is there a command to search the ENTIRE design (all .vhd files and Megawizard functions) for a certain signal?
Assuming you've gone through synthesis, go to View -> Utility Windows -> Node Finder and search on Design Entry(All Names).
grep, it gets installed with Nios II EDS (run Nios II Command Shell, cd /cygdrive/<drive_letter>/<path>/<to>/<project>)
Not part of Quartus, but ultra edit allows you to do exactly what you want.
I tried the node finder but nothing pops up. It seems to be unresponsive
