Programmable Devices
21607 討論
Shared reconfiguration controller for 2 (separate) transceivers
arno_va
新貢獻者 I
2,015 檢視
For my design I'm using a Cyclone V FPGA with 3 transceivers. My design requires 2 separate (duplex) transceiver fiber links. To accomplish this I'm using 2 separate transceiver instances and I assumed it would require 2 separate reconfiguration controllers as well. But as it turns out when I try to compile my design it doesn't work. I'm getting "Error (11687): Channel stm_fbr_tx_out(n) is assigned to location PIN_U1, channel adc_fbr_tx_out(n) is assigned to location PIN_Y3, however channels with different reconfiguration controllers cannot be placed in the same channel triplet. Modify your design so the two channels share the same reconfigure controller."
I tried to find how I can make this work (without combining the 2 separate transceivers into 1 (with 2 lanes), but I can't find any eg. documentation about this. Can I even have 2 completely separate transceivers with a single reconfiguration controller. And if so: how do I all tie it together?
Any help would be greatly appreciated since I'm completely stuck at the moment.
標籤 (1)
0 積分
1 解決方案
arno_va
新貢獻者 I
1,799 檢視
Hi Zying,
One small question. Is it correct that when I create 2 separate transceiver instances, I need a (single) reconfig-controller with the following settings: "Number of reconfig interfaces = 4" and "Optional interface grouping = 2,2" ?
Kind regards,
Arno
在原始文章中檢視解決方案
11 回應
ZiYing_Intel
員工
1,992 檢視
Hi arno_va,
Can you share your .qar file here? So that I can try debug the issue from my side.
zying
arno_va
新貢獻者 I
1,979 檢視
Dear Zying,
Thanks for your reply. I will provide the .qar-file as soon as I'm back at work (tomorrow).
Just to clarify about what I'm trying to accomplish: I basically want to interface a single C5G board with 2 (fiber) transceivers to 2 other C5G boards (each with a single transceiver).
Kind regards,
Arno
arno_va
新貢獻者 I
1,961 檢視
Dear Zying,
Here's the qar-file you requested. Hopefully it helps in resolving the issue.
ps. the transceiver/reconfig ip instances are at the bottom of the top-level.
Cheers,
Arno
arno_va
新貢獻者 I
1,910 檢視
Dear Zying,
Any update on this?
Kind regards,
Arno
ZiYing_Intel
員工
1,861 檢視
Hi amo_va,
I would suggest you to use one reconfig controller. The same triplet can only be driven by no more than one reconfiguration controller. Thus, the two channels need to be driven by the same reconfig controller.
zying
ZiYing_Intel
員工
1,812 檢視
I wish to follow up.
Do you still have any question about this issue?
zying
arno_va
新貢獻者 I
1,800 檢視
Hi Zying,
Kind regards,
Arno
ZiYing_Intel
員工
1,750 檢視
Hi Amo,
It's ok if you are using Cyclone V.
zying
ZiYing_Intel
員工
1,741 檢視
Hi Amo,
For your .qar file, we found the error already. It was the pin placement causes fitter error. When change Ch1 =>Ch2, it resolve fitter error.
zying
arno_va
新貢獻者 I
1,732 檢視
Hi Zying,
Ah yes, thanks! That solved it
Kind regards,
Arno
ZiYing_Intel
員工
1,692 檢視
Since the issue has been resolved, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue. There will have people reach out to you.
zying
回覆
