Any other simulation tools which is easy to use and can get the user manual/other document related to the tools easily? Thanks. :oops:
Are you referring to design functional simulation? If yes, I think the Modelsim Altera starter edition will be a good one to start with.
Table 2 from link below might give you some ideas regarding the simulations information:
https://www.altera.com/support/support-resources/design-software/modelsim.html- Mark as New
ops.. I mean any other functional simulation tools other than modelsim?
@Irish having error to open ur link.- Mark as New
ops.. I mean any tools other than modelsim can do functional simulation?
Perhaps you may refer to the link below:
https://www.altera.com/support/support-resources/design-software/quartus-ii/simulation.html It would cover the simulation tools other than modelsim. For signal integrity check, you could have the IBIS simulation.- Mark as New
There are several tools
Modelsim Active hdl Ncsim These all require a license, but have lots of features. Some have cute down free version. There are a few free vhdl and verilog simulators, but they are mostly hobby projects, harder to use and no where near as fully featured.- Mark as New
Hi Metaboy,
If you are working with the Altera FPGA, I think the best would be to use the Modelsim Altera Starter edition because it is free and also come with pre-compiled Altera libraries which will ease you simulation.- Mark as New
Found that commands required to run simulation with modelsim. Where can I get the list of commands? Thanks.
Modelsim has full documentation in the /docs/ folder
