I connect FXOS8700CQ to SoC with Intel FPGA Avalon I2C (Master) Core.
Add to *.dts:
i2c_accelerometer: i2c@0x000010300 {
compatible = "altr,softip-i2c-v1.0";
reg = <0x00000000 0x00010300 0x00000040>;
interrupt-parent = <&hps_0_arm_gic_0>;
interrupts = <0 51 4>;
clocks = <&clk_0>;
clock-frequency = <100000>;
#address-cells = <1>;
#size-cells = <0>;
fifo-size = <32>;
}; //end i2c@0x000010300 (i2c_accelerometer)
Program:
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/i2c.h>
#include <linux/i2c-dev.h>
#include <unistd.h>
#define I2C_ADAPTER "/dev/i2c-0"
void read_buffer(int fd, unsigned short addr)
struct i2c_rdwr_ioctl_data data;
struct i2c_msg messages[2];
unsigned char write_buf[1] = {0x0D}, read_buf[1] = {0x00};
* .addr - Адрес устройства (датчика)
* .flags - операция чтения или записи (0 - w, 1 - r)
* .len - кол-во передаваемых/принимаемых сообщений
* .buf - буфер на чтение или запись
messages[0].addr = addr;
messages[0].flags = 0;
messages[0].len = 1;
messages[0].buf = write_buf;
messages[1].addr = addr;
messages[1].flags = 0x1;
messages[1].len = 1;
messages[1].buf = read_buf;
data.msgs = messages;
data.nmsgs = 2;
ioctl(fd, I2C_TIMEOUT, 2); // set the timeout
ioctl(fd, I2C_RETRIES, 4); // set the retries
if (ioctl(fd, I2C_RDWR, &data) < 0)
printf("Cant send data!\n");
else
printf("ID = 0x%x\n", read_buf[0]);
int main(int argc, char **argv)
int fd;
* Open I2C file descriptor.
fd = open(I2C_ADAPTER, O_RDWR);
if (fd < 0) {
printf("Unable to open i2c file\n");
return 0;
while(1)
read_buffer(fd, 0x1E);
sleep(1);
return 0;
I expect to see on i2c bus:
ST-ADDRESS-W-ACK-DATA-ACK-ST-ADDRESS-R-ACK-DATA-ACK-SP
But in reality, I see:
ST-ADDRESS-W-ACK-DATA-ACK-SP-ST-ADDRESS-R-ACK-DATA-ACK-SP
For this reason, reading does not work.
How I can set read/write transaction without stop in between?
Probably a problem in Linux driver i2c-altera.c
According to the documentation (Documentation/i2c/dev-interface):
ioctl (file, I2C_RDWR, struct i2c_rdwr_ioctl_data * msgset)
Do combined read / write transaction without stop in between.
Only valid if the adapter has I2C_FUNC_I2C. The argument is
a pointer to a
struct i2c_rdwr_ioctl_data {
struct i2c_msg * msgs; / * ptr to array of simple messages * /
int nmsgs; / * number of messages to exchange * /
The msgs [] themselves contain further pointers into data buffers.
If you’re looking at what I2C_M_RD I’m flag on
Overlaying the ivectl's
The i2c-altera.c driver has I2C_FUNC_I2C:
static u32 altr_i2c_func (struct i2c_adapter * adap)
return I2C_FUNC_I2C | I2C_FUNC_SMBUS_EMUL;
The driver sets STOP when i2c_msg.len = 1 (last data byte):
static void altr_i2c_transfer (struct altr_i2c_dev * idev, u32 data)
/ * On the last byte, send STOP * /
if (idev-> msg_len == 1)
data | = ALTR_I2C_TFR_CMD_STO;
if (idev-> msg_len> 0)
writel (data, idev-> base + ALTR_I2C_TFR_CMD);
Correctly put STOP after the last byte of the last message.
Any thoughts on how to fix this?
Do you mind to share with us which coding that you have make the changes for the driver to be working?
Hi, KTan9.
Yes, a modified driver file has been attached to the previous message. Unfortunately, I am not an expert in creating drivers and my fixes are probably not optimal and need to be corrected. I wrote to the driver author (Thor Thayer from Intel), but I haven’t received a response yet.
Let me know any news on this issue.
