I download AN 488(Stepper Motor Controller Using MAX II CPLDs) design example from the official website of ALTERA.
the following is the code
* Stepper motor Controller
* December 2006
//TOP LEVEL MODULE
module stepmot(reset,dir,mode,move,phaseout); //module stepmot is the top level module.
input reset,mode,dir,move; //reset when asserted brings the shaft to reference position.
output phaseout; //mode specifies step operation or continuous operation.
wire osc,clk; //dir is for clockwise or anti clockwise motion.
wire oscena; //move shifts the shaft by half step in step mode.
assign oscena=1'b1;
/* Instantiation of ufmclk module. */
ufmclk ufmclk1(
.oscena (oscena),
.osc (osc));
/* Instantiation of clk divider module.*/
divider d1(
.osc (osc),
.clk (clk));
/* Instantiation of controller module.*/
stepper s1(
.clk (clk),
.reset (reset),
.dir (dir),
.mode (mode),
.move (move),
.phaseout (phaseout));
endmodule
/* Module stepper is the motor controller module */
module stepper (clk,reset,dir,mode,move,phaseout);
input clk,reset,dir,mode;
input move;
output phaseout;
reg phaseout,position;
always@(posedge clk or negedge reset) begin
if(reset==0) begin // motor resets to 0111 at reset=0
phaseout=4'b0111;
end else begin
/* Mode=0 for continous motion */
if (mode==0) begin
//dir=0 for anticlockwise motion
case({phaseout}) //dir=1 for clockwise motion
4'b0111 : if (dir==0)
phaseout=4'b0110;
else
phaseout=4'b0011;
4'b0011 : if(dir==0)
phaseout=4'b0111;
else
phaseout=4'b1011;
4'b1011 : if (dir==0)
phaseout=4'b0011;
else
phaseout=4'b1001;
4'b1001 : if (dir==0)
phaseout=4'b1011;
else
phaseout=4'b1101;
4'b1101 : if (dir==0)
phaseout=4'b1001;
else
phaseout=4'b1100;
4'b1100 : if (dir==0)
phaseout=4'b1101;
else
phaseout=4'b1110;
4'b1110 : if (dir==0)
phaseout=4'b1100;
else
phaseout=4'b0110;
4'b0110: if (dir==0)
phaseout=4'b1110;
else
phaseout=4'b0111;
default: $display("inavlid input");
endcase
/* Mode=1 for step motion */
end else begin
if(move==1'b0) begin
case ({position})
phaseout=4'b0110;
else
phaseout=4'b0011;
phaseout=4'b0111;
else
phaseout=4'b1011;
phaseout=4'b0011;
else
phaseout=4'b1001;
phaseout=4'b1011;
else
phaseout=4'b1101;
phaseout=4'b1001;
else
phaseout=4'b1100;
phaseout=4'b1101;
else
phaseout=4'b1110;
phaseout=4'b1100;
else
phaseout=4'b0110;
4'b0110 : if (dir==0)
phaseout=4'b1110;
else
phaseout=4'b0111;
endcase
end
end
end
end
/* Motor moves half step on the negetive edge of move*/
always@(negedge move or negedge reset) begin
if (reset==0)
position=4'b0000;
else if(reset==1)
position=phaseout;
end
endmodule
Module ufmclk is the module
which gets the clock from the oscillator
`timescale 1 ps / 1 ps
//synopsys translate_on
module ufmclk_altufm_osc_7p3
osc,
oscena) /* synthesis synthesis_clearbox=1 */;
output osc;
input oscena;
wire wire_maxii_ufm_block1_osc;
maxii_ufm maxii_ufm_block1
.arclk(1'b0),
.ardin(1'b0),
.arshft(1'b0),
.bgpbusy(),
.busy(),
.drclk(1'b0),
.drdout(),
.drshft(1'b0),
.osc(wire_maxii_ufm_block1_osc),
.oscena(oscena)
`ifdef FORMAL_VERIFICATION
`else
// synopsys translate_off
`endif
.drdin(1'b0),
.erase(1'b0),
.program(1'b0)
`else
// synopsys translate_on
`endif
.ctrl_bgpbusy(),
.devclrn(),
.devpor(),
.sbdin(),
.sbdout()
defparam
maxii_ufm_block1.address_width = 9,
maxii_ufm_block1.osc_sim_setting = 180000,
maxii_ufm_block1.lpm_type = "maxii_ufm";
assign
osc = wire_maxii_ufm_block1_osc;
endmodule //ufmclk_altufm_osc_7p3
//VALID FILE
module ufmclk (
oscena,
osc)/* synthesis synthesis_clearbox = 1 */;
input oscena;
output osc;
wire sub_wire0;
wire osc = sub_wire0;
ufmclk_altufm_osc_7p3 ufmclk_altufm_osc_7p3_component (
.oscena (oscena),
.osc (sub_wire0));
endmodule
* Module divider divides the clock from ufmclk to produce
* a clock suitable to drive the motor controller
module divider (osc, clk);
input osc;
output clk;
reg clk;
reg count;
initial count=17'b00000000000000000;
always @( posedge osc)
begin
count = count + 1;
clk = count;
end
endmodule
/***********************************END OF PROGRAM.**********************************************/
But I can't understand the codes from the 140 line to the 179 line? what is the function of these codes? can you explain the meaning of the codes ? can the 'initial ' synthesis in the verilog!
