Programmable Devices
21615 Discussions
Suggestions for development kit
Hi
I am searching for FPGA board that will be in smallest size ( priority for Altera ) with:
1.RS232 port
2.GPIO port
3.2-3 swith
4.push buttons is optional
Now i have DE1 board and i want to use my project on some smallest size board that can answer my project requirements.
Any suggestions?
Thanx
--- Quote Start ---
1.RS232 port
2.GPIO port
3.2-3 swith
Any suggestions?
--- Quote End ---
The BeMicro has an FTDI FT2232, with one of the interfaces used to control JTAG and the other connected as a UART ... not quite RS232, but perhaps all you want is host-to-FPGA via COM port.
The DE-nano probably has most of what you want too - except for the RS232 UART. But you could always buy a FTDI USB-to-UART breakout cable (the cable has UART signals, not RS232 signals, so you can plug it into a header directly).
http://search.digikey.com/us/en/products/ttl-232r-3v3/768-1015-nd/1836393
Cheers,
Dave
Would a JTAG UART be good enough? nios2-terminal and system console can access that from the host side.
