21615 Discussions
Synchronous Design
I have got timing problems with a ACEX1K30 Design. To solve my problems I want to change my design in a synchronous design (only one global clock).
Where can I find examples for synchronous designs?
I use the Quartus (Web-Edition) graphical editor (no VHDL or HDL, sometimes AHDL).
I have to realize:
Eventcounter (up/down), Ratemultiplier, Frquency-Divider, Monoflop, Timer (Shiftregister), Data Register (from µC).
I suggest you google with the following words.
Verilog Synchronous design
or
Vhdl Synchronous design
This will provide much help for you.
I suggest you the vhdl instruction
if clk'event and clk = 1
the vhdl (or verilog) language guarantee to you about freedom degrees...some things with these graphical tools is much more complicate....
smile
stefania:)
Thank you Avatar, I will try but I think I will have problems with understanding VHDL or Verilog HDL.
Hi Helmut,
what kind of Problem you have? What forfrequencies are needed? Do you use you global the Clock Input?In my first Time i wrote also all in AHDL.
--- Quote Start ---
--- Quote End ---
Even if you're just starting out learning and not doing a design for actual hardware, it is best to use a modern device family. Some Quartus features are not available for old device families, so you won't be able to do everything you could do for an new real design using a recent (or at least more commonly used) device family.
See related comments at "Altera Forums > General > General Altera Discussion > ACEX1k" (http://www.alteraforum.com/forum/showthread.php?t=457&highlight=acex1k).
If I'm just experimenting and not doing something device-specific, I like to choose the smallest device in one of the Cyclone families for quick compile times.
