Programmable Devices
21613 Discussions
TimeQuest asynchronous path
Hi all.
I'm trying to interface a cyclone II device to an (asynchronous) SRAM (DE2 board). I have a written memory controller, and for a read operation I wait for several clock cycles (25Mhz) with the address registered and ce/we/oe
with the proper values - and after a fixed period of time has passed - I sample the SRAM output data inside the FPGA.
a second feature I have is registering the address and at next clock edge - registering the SRAM data outputs (asynchronous path: FPGA address reg --> SRAM address inputs --> SRAM data outputs --> FPGA data inputs).
I would like to constrain the path with the TimeQuest by setting the input / output delay. what I had in mind is setting the output delay to:
outputdelay_max=board_delay+SRAM_read_delay+Tsu (FPGA clock setup,
since the sampling clock is the FPGA's clock itself).
am I wrong? should I try a different approach? and can I use the latter
and not introduce an input delay?
Thanks in advance,
Eyal.
