Programmable Devices
21605 讨论
TimeQuest report timing finds 2 paths inside the Cyclone 2 FPGA for the same design path
Cliver1
新手
1,285 次查看
Hello, when I analyse the path from P1_EnergyMonAInClk40m[6] to P1_PeakPowerClk40m[6] for example in my design using Report Timing in TimeQuest 2 paths are reported with different timing delays. The attached timing report screenshots and chip planner show what is happening.
P1_EnergyMonAInClk40m[6] is clocked in from I/O pin AdcDa[6] on the rising edge of a 40MHz clock.
The device is a Cyclone 2 EP2C15AF256C8 and I use Quartus II 12 service pack 2 web edition.
Any ideas why the 2 paths are reported?
Clive
标签 (1)
0 项奖励
1 解答
Cliver1
新手
1,276 次查看
False alarm. There are 2 possible data paths in my design!
在原帖中查看解决方案
0 项奖励
3 回复数
Cliver1
新手
1,277 次查看
0 项奖励
SyafieqS
员工
1,246 次查看
Let me know if there is any other concern regarding this.
0 项奖励
SyafieqS
员工
1,195 次查看
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
0 项奖励
回复
