21615 Discussions
Transceiver placement issue
There is one block, four transceivers in an EP4CGX22 FPGA chip. If i need to use it to design two independent transceiver links, each one with 2 transceiver channel bonded, is it OK?
Thanks a lot.
Yaoting
You don't say which package. If it is the F169 version, that only has 2 transceivers. The F324 version has 4.
But even still, if you read page 1-37 of Volume 2 of the Cyclone IV handbook it says:
"When implementing ×2 bonded channel configuration in a transceiver block,
remaining channels 2 and 3 are available to implement other non-bonded channel
configuration."
So you can only have one bonded design, not two.
Besides the different clocking approaches what are other benefits or risks between using 2 non-bonded channel protocol and one bonded X2 channel protocol?
Appreciate your helps.
any one can help?
