High,
i want to start programming FPGA, i use the Terasic DE2-115 eval Board. I installed the USB-Blaster driver which is recognized in the Windows10 Device manager but i can't see it in the programming windows of the Quartus II 10.0 Web Edition.
Have you got an idea why it doesn't appear and how i can solve this issue?
Best regards!
Ettien
連結已複製
Hi SStrell, yeah the device manager can detect the usb balster but not the Quartus II 10.0 or 12.0. I donwloaded the latest version of the USB blaster 16.0 but it still doesn't work.
Update drivers, check the USB blaster cable connection wit the board, check the visual inspection the board especially FPGA pins & refer the link below,
https://www.intel.com/content/www/us/en/programmable/documentation/nfa1418282998564.html
Try to check with Stand alone programmer,
https://www.intel.com/content/www/us/en/programmable/downloads/software/prog-software/100.html
Why don`t you use latest Quartus lite version?
Vicky
Finally I installed the latest Quartus lite version 18.1. It can detect the ubs blaster 2 hardware, but unfortunately I can’t download my FPGA program, it failed.
I also got a lot of error message when running the the DE2_115_control_panel from the DE2-115_v.3.0.6_SystemCD folder.
Best regards !
Ettien
Hi Ettien,
Delete the 'db' & 'incremental_db' folder from your project directory.
Perform 'Full Compilation' in Quartus lite 18.1 & the try to program DE2_115 board.
please let me know if you have any different concern.
Vicky
Hi finally,
i solved the issue following theses steps :
1- Install the latest version of quartus Lite 18.1.
2- Download the latest version of DE2-115 CD from terasic website.
3- Change the environment variables to path the quartus installation folder.
4- When running the Control panel, be sure to have the swith on the RUN mode otherwise it doesn't work.
You can find more details on the link bellows :
https://www.coursehero.com/file/27366819/Run-control-panel-under-Quartus-II-150-or-late-versionpdf/
Hope it can help!!!
Best regards.
