21611 Discussions
Unable to establish a link of RapidIO
晓郝
When I use RapidIO in Arria 10 to communicate with DSP , I find port_initialized of IP core is high , but the port_ok of the port 0 error and status CSR-offset:0x158 is low. According to RapidIO Gen1 Debug Checklist of INTEL FPGA WiKi , I check the steps of Unable to establish a link , but the issue still exist.
Nathan_R_Intel
Hie, Can you help clarify if your design is unable to establish a link although CSR 0x158 = 0 and port_initalized goes HI? Regards, Nathan
晓郝
When DSP complete the initialization, the port_initialized of FPGA IP core is high, but CSR 0x158 = 1 ,
the PORT_UNINIT of this register is 1, the PORT_OK of this register is 0 . Besides I find  the
no_sync_indicator is 1. What maybe  bring on unable to establish a link.
Tah
Nathan_R_Intel
Hie Tah, Some of the reasons for cannot establish link is already provided in the Intel FPGA Wiki section below such as link partner does not match core configuration, core in reset, timing no met, incorrect analogue settings etc. https://fpgawiki.intel.com/wiki/RapidIO_Gen1_Debug_Checklist#Unable_to_establish_a_link Hence, please check the other checklist questions related to link cannot establish. Regards, Nathan
晓郝
晓郝
​hi,
OK, I will check that again.
Nathan_R_Intel
Please advice if issue is resolved. Regards, Nathan
ghe001
楼主,问题解决了没?我也遇到同样的问题,能否共享一下解决办法,谢谢。
