21611 Discussions
Unable to run different versions of altera libraires
I am new to FPGA simulation.I was given with a qsys file.From this qsys I should generate system & tb and should simulate them.
Here i am using quartus 15.1.2.193.Some libraries are getting generated from earlier version of quartus(say 14.0).
So whenever I try to simulate them in uvm I am facing this below error.
ncsim: *F,NOLWSV: Searching for import subroutine "axi_set_master_end_abstraction_level" in default library libdpi. Unable to load the default library libdpi.
I am using ncsim.
can anyone help me in clean this errorS?
Got the same error, anyone can help ? thanks a lot.
Is this error fixed?? I am facing this issue currently....:confused::confused:
SAME here.
