Hey all
A bit confused about the choosing of the linker script for the unhosted baremetal. At all the examples with the EDS its clearly written : " Derived from file "armulator-ram-hosted.ld"" but if I look at the first .text section : PROVIDE(__cs3_reset = __cs3_reset_generic); If I look at the objdump I see that the __cs3_reset function jumpes to __cs3_start_asm_sim if I change to "PROVIDE(__cs3_reset = __cs3_reset_armulator_ram);" the "__cs3_start_asm_sim" becomes just "_start" this bothers me because "__cs3_start_asm_sim" contains "svc 0x00123456 " instruction even if I link it with the unhosted option(which I suspect being problematic) If I look at the codesourcery documentation I dont see common startup code sequence for cyclone 5 (only for cyclone 3)Link Copied
Topic Options
