21611 Discussions
Using M4K mem for large shift registers
Hi
I am trying to define a Large SR and want it to be implemented with memory
and not Logical elements (otherwise it will not fit the device)
what should I add to my verilog code and what settings in the Quartus should I change in order to do that?
all my atteps so far had failed
:confused:
(* ramstyle = "M4K" *) reg [15:0] InLine[2677:0];
//################ InData to Shift Reg# #########################
always@(negedge Rx_clk_A) // Shift Reg for the incoming data
begin // S.R. starts only when "write_port_A" is high
if ( write_port_A ) // i.e. valid recording condition for HDR + Image
begin
for (I=0 ; I<2677 ; I=I+1)
begin
InLine[I+1] <= InLine[I];
InLine[0] <= l[15:0];
//InLine[0] <= Danny_LinkA_Data;
end
end
end
You could start by using ALTSHIFT_TAPS megafunction.
(http://www.altera.com/literature/ug/ug_alt_shift_taps.pdf)
Thanks I will try that also.
but is this the write syntex to tell the quartus to implement this with a memory block?
to achive that is there any settings I should change inthe quartus?
Urilis
In order to implement a simple shift-register, you should make an structured description of hardware. First, describe your RAM Block as a single module.
Shift Register can be implemented as a Circular Buffer with a FIFO behaviour, where input data are writen in head address and output data is read from tail addresss.
Read and write address generators can be implemented with
mod-N counters, each one pre-loaded with 0 and N-1 respectively, N is the shift-register size.
According to the Quartus software manual, a shiftregister in RAM (an ALTSHIFT_TAPS megafunction) can be inferred from a behavioural description. With default settings, no additional synthesis attribute is required for a sufficient large shift register.
As you reported, this method seems not to work with your code, but I don't know why. You may try to reproduce the suggested example more exactly.
The Quartus manual mentions several conditions for succesful SR inference:
--- Quote Start ---
To be detected, all the shift registers must have the following characteristics:
&#9632; Use the same clock and clock enable
&#9632; Do not have any other secondary signals
&#9632; Have equally spaced taps that are at least three registers apart
--- Quote End ---
I tried with the Verilog template for one-bit wide, n-bit long shift register. It's always implemented in RAM, unless I disabled SR recognitaion for the module.
(* altera_attribute = "-name AUTO_SHIFT_REGISTER_RECOGNITION OFF" *)
