Programmable Devices
Comunicados
VGA output
Colaborador honorário II
1.863 Visualizações
hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks..
sample codes would be really helpful.. :D
4 Respostas
599 Visualizações
--- Quote Start ---
--- Quote End ---
You need to understand VGA timing, how "new" are you to VHDL? Anyway, the DE1 User's manual has a section on VGA timing. You basically need to generate those signals. Here is more information for higher resolutions:
http://tinyvga.com/vga-timing
Good luck.
Bart
599 Visualizações
if you have any dev board like NEEK or DE0 from terasic or so.
599 Visualizações
You should take a look at the University Program from Altera
ftp[dot]altera[dot]com/up/pub/Altera_Material/10.1
The component is called "altera_up_avalon_video_vga_controller"
Good luck
599 Visualizações
--- Quote Start ---
--- Quote End ---
Speaking of Altera wiki I forgot that I posted sample VGA VHDL for DE1 :D:
http://www.alterawiki.com/wiki/de1_board
Good luck.
Bart
Responder
