- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks..
sample codes would be really helpful.. :DLink copiado
4 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks.. sample codes would be really helpful.. :D --- Quote End --- You need to understand VGA timing, how "new" are you to VHDL? Anyway, the DE1 User's manual has a section on VGA timing. You basically need to generate those signals. Here is more information for higher resolutions: http://tinyvga.com/vga-timing Good luck. Bart
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
if you have any dev board like NEEK or DE0 from terasic or so.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You should take a look at the University Program from Altera
ftp[dot]altera[dot]com/up/pub/Altera_Material/10.1 The component is called "altera_up_avalon_video_vga_controller" Good luck- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks.. sample codes would be really helpful.. :D --- Quote End --- Speaking of Altera wiki I forgot that I posted sample VGA VHDL for DE1 :D: http://www.alterawiki.com/wiki/de1_board Good luck. Bart
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
