21615 Discussions
[VHDL] Different synthesis results after using "generate"
I used 'generate' statement to order several similar components, but after that synthesis results are slightly different.
Does anyone know what can cause this? Theoretically there is no difference between these two versions, all connections are the same. Is it matter of some compiler settings?
Sz.
Assuming by "results" you mean testing results then either you observation is wrong or your test is wrong or your connections are wrong or you have timing violations.
Without further information, it is only matter of speculations
If by "results" you mean resource utilisation then a difference is not a surprise.
please post your code, and tell use how generate modified the design.
Thanks for replies. By "results" I mean resource utilisation and timing analysis results.
I have a FIR filter with a chain of 8 MAC modules:
--- Quote Start ---
mac0 : mac
port map ( aclr0 => mac_rst,
clock0 => clk,
dataa => sample(0),
datab => coeff(0),
overflow => of(0),
result => sum(0)
mac7 : mac
clock0 => clk,
dataa => sample(7),
datab => coeff(7),
overflow => of(7),
result => sum(7)
--- Quote End ---
Sample, coeff and sum are arrays of vectors.
Instead, I wrote it like this:
--- Quote Start ---
mac_components : for i in 0 to 7 generate
begin macs : component mac
port map(mac_rst, clk, sample(i), coeff(i), of(i), sum(i));
[/INDENT]end generate mac_components;
--- Quote End ---
I'm not sure about this change because, according to TQ, timing results are a bit worse (but still within margin).
Should I be so careful with this type of code?
The generate statement should be identical to the above code.
But a different random seed for the fitter may have been used, which can affect the timing. Resource usage should be the same.
Ok, thanks. Resource utilisation is a little different too, but I'll send it for testing anyway.
synthesis results:)
