21615 Discussions
VREF pin and EPCS and OCT questions
1. In the Cyclone iii's Pin Guidelines, it says" the VREF pins are available as user I/O pins. All of the VREF pins within a bank are shorted together." Does it mean that the four VREF pins in a bank are shorted when they are I/O pins? And how i set them as I/O pins?
2. How can i use the EPCS as an external flash? Do i need another pin to control the CS pin of the EPCS?
3. How can i set the OCT? I don't know how to enable the OCT.
Thank you!
1. no, they are individual I/O, not tied together. you can use the pin planner to assign your design's ports to the VREF pins and QII will use that as a user I/O
2. take a look at the EPCS Controller
3. go to Assignments > Settings, create a new assignment for your pin and select Output Termination as the Assignment Name, and select a value
Thank you.
But i use the Quartus 7.2, and i only find a "Enable OCT DONE" option. Can someone tell me how to enable the OCT?
use 9.1sp2 or 10.0 Web Edition :)
