21611 Discussions
Verilog Language to desribe top entity
I used a DE2_NIOS project in the Altera CD , and modify(delete some unnecessary modules , and add some pio modules ) it properly to be used as a uclinux project.
Modification is ONLY done in the SOPCBuilder.
So I use the default old DE2_NIOS.sof , and the uclinux works on the board. It's quite strange.
However, when I compile it in the QuartusII ( only delete some pins in the .v top entity file ) and complete the compilation.
and program the newly sof file into the board, uclinux doesn't work.
I mean, how to modify the .v top entity file, to become a qualified .v file as the top entity of the project of uclinux.
¿did you keep the timer module?.
¿doe's a simple Nios II IDE project run on your system?
--- Quote Start ---
--- Quote End ---
Actually, I use the example of Altera CD to build a two cpu project.
Including the timer module, and set another internal timer for cpu1.
--- Quote Start ---
--- Quote End ---
Maybe I should re-modify the project in QuartusII, reassign the pins of the project.
And the sof file may have its effect , uclinux system can run with it.
