Hello everybody,
I created a design with buttons where a led lights on when pressing a button. My quartus II design works; I checked the pin assignments and the buttons signals with SignalTap. I have no error in the compilation in NIOS II IDE but then leds do not light on. I noticed on SignalTap that when I did not press any button, the signal was 1111. Thus, I tried to write (!button) instead of (button) in LED_PIO_BASE. Afterwards, LED1 lighted on even though I was not pressing any button. I used hello_led with this quartus II design which works perfectly. The problem really comes from the buttons. Any idea ? Please help, I am lost. Myriam If it can help to understand my problem, I used the following program: # include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "stdio.h"# include "stdlib.h" int alt_main (void) { alt_u8 button; while(1){ button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, button); } return 0; }Link Copied
If you want one's complement "button" variable, you should use "~button" not "!button". What is common in your leds, anode or cathode?
Thank you for ~button, I changed it. For the leds, I don't know I am gonna check this. I have a Cyclone III C25 from Altera.
When doing further tests, I noticed that button always remained at 0. Is there an initialisation to make to the variable button (knowing that I use the pooling method)? Why button value does not change ?- Mark as New
If you have the "Cyclone III FPGA Starter Board" (Neek), LEDs are anode common on it, so you dont' need one's complement. What do you get when doing printf("%d",button);?
do signaltap button signals change when a button is pressed?- Mark as New
SignalTap is 1111 when I don't press any button. When pressing a button, the signal goes down to 0 (for example, pressing button1 gives 0111).
When doing printf("%d",button), the console keeps displaying 0 whatever I do, pressing or not a button.- Mark as New
So, check the connection between the PIO's export signals and buttons. Be sure PIO is just for reading in SOPC Builder.
I checked I had the right names by looking at system.h.
How can I check the connection between PIO's export signals and buttons ? I am a newbie in quartus II.- Mark as New
This connection is made in the top-level entity. Top level entity instances the sopc builder system. Verify the button PIO is just for reading.
It seems like buttons are just for reading. I put the module definition below. Am I right ? Any other idea ?
In the module, I chose "input ports only" and did not specify any input options. Maybe it comes from my pin assignment, I only added the following assignments in my tcl : set_location_assignment PIN_F1 -to button[0] set_location_assignment PIN_F2 -to button[1] set_location_assignment PIN_A10 -to button[2] set_location_assignment PIN_B10 -to button[3] I let the I/O standard to 2.5V and the current strength to 8mA. May it come from this ? Thanks, Myriam Here is my module : module button_pio ( // inputs: address, clk, in_port, reset_n, // outputs: readdata ) ; output [ 3: 0] readdata; input [ 1: 0] address; input clk; input [ 3: 0] in_port; input reset_n; wire clk_en; wire [ 3: 0] data_in; wire [ 3: 0] read_mux_out; reg [ 3: 0] readdata; assign clk_en = 1; //s1, which is an e_avalon_slave assign read_mux_out = {4 {(address == 0)}} & data_in; always @(posedge clk or negedge reset_n) begin if (reset_n == 0) readdata <= 0; else if (clk_en) readdata <= read_mux_out; end assign data_in = in_port; endmodule- Mark as New
Could you post your top-level entity instead. Your pin assignments are right.
Thanks for helping me. Here is my top level entity :
module niossram ( // inputs: osc_clk, reset_n, button, // outputs: flash_ssram_a, flash_ssram_d, led, ssram_adsc_n, ssram_bw_n, ssram_bwe_n, ssram_ce_n, ssram_clk, ssram_oe_n ); input osc_clk; input reset_n; input [ 3: 0] button; output [ 23: 0] flash_ssram_a; inout [ 31: 0] flash_ssram_d; output [ 3: 0] led; output ssram_adsc_n; output [ 3: 0] ssram_bw_n; output ssram_bwe_n; output ssram_ce_n; output ssram_clk; output ssram_oe_n; wire [ 3: 0] led_n; wire [ 3: 0] button_n; assign ssram_clk = osc_clk; assign led = ~led_n; niossram_sopc niossram_sopc_instance ( .in_port_to_the_button_pio (button_n), .adsc_n_to_the_ssram (ssram_adsc_n), .bw_n_to_the_ssram (ssram_bw_n), .bwe_n_to_the_ssram (ssram_bwe_n), .chipenable1_n_to_the_ssram (ssram_ce_n), .address_to_the_ssram (flash_ssram_a), .data_to_and_from_the_ssram (flash_ssram_d), .clk (osc_clk), .out_port_from_the_led_pio (led_n), .outputenable_n_to_the_ssram (ssram_oe_n), .reset_n (reset_n), ); endmodule- Mark as New
You don't have connected the "button" input to your PIO
--- Quote Start --- .in_port_to_the_button_pio (button_n), --- Quote End --- or you should have this statement --- Quote Start --- assign button_n = ~button; --- Quote End --- The statement --- Quote Start --- assign led = ~led_n; --- Quote End --- should be --- Quote Start --- assign led_n = ~led; --- Quote End ---- Mark as New
Thank you very much !!!
