Programmable Devices
21615 Discussions
Buttons communication problem NIOS II
Hello everybody,
I created a design with buttons where a led lights on when pressing a button. My quartus II design works; I checked the pin assignments and the buttons signals with SignalTap. I have no error in the compilation in NIOS II IDE but then leds do not light on.
I noticed on SignalTap that when I did not press any button, the signal was 1111. Thus, I tried to write (!button) instead of (button) in LED_PIO_BASE. Afterwards, LED1 lighted on even though I was not pressing any button.
I used hello_led with this quartus II design which works perfectly. The problem really comes from the buttons.
Any idea ? Please help, I am lost.
Myriam
If it can help to understand my problem, I used the following program:
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "stdio.h"# include "stdlib.h"
int alt_main (void)
alt_u8 button;
while(1){
button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, button);
return 0;
If you want one's complement "button" variable, you should use "~button" not "!button". What is common in your leds, anode or cathode?
Thank you for ~button, I changed it. For the leds, I don't know I am gonna check this. I have a Cyclone III C25 from Altera.
When doing further tests, I noticed that button always remained at 0. Is there an initialisation to make to the variable button (knowing that I use the pooling method)? Why button value does not change ?
If you have the "Cyclone III FPGA Starter Board" (Neek), LEDs are anode common on it, so you dont' need one's complement. What do you get when doing printf("%d",button);?
do signaltap button signals change when a button is pressed?
SignalTap is 1111 when I don't press any button. When pressing a button, the signal goes down to 0 (for example, pressing button1 gives 0111).
When doing printf("%d",button), the console keeps displaying 0 whatever I do, pressing or not a button.
So, check the connection between the PIO's export signals and buttons. Be sure PIO is just for reading in SOPC Builder.
I checked I had the right names by looking at system.h.
How can I check the connection between PIO's export signals and buttons ? I am a newbie in quartus II.
This connection is made in the top-level entity. Top level entity instances the sopc builder system. Verify the button PIO is just for reading.
It seems like buttons are just for reading. I put the module definition below. Am I right ? Any other idea ?
In the module, I chose "input ports only" and did not specify any input options.
Maybe it comes from my pin assignment, I only added the following assignments in my tcl :
set_location_assignment PIN_F1 -to button[0]
set_location_assignment PIN_F2 -to button[1]
set_location_assignment PIN_A10 -to button[2]
set_location_assignment PIN_B10 -to button[3]
I let the I/O standard to 2.5V and the current strength to 8mA. May it come from this ?
Myriam
Here is my module :
module button_pio (
// inputs:
address,
clk,
in_port,
reset_n,
// outputs:
readdata
output [ 3: 0] readdata;
input [ 1: 0] address;
input clk;
input [ 3: 0] in_port;
input reset_n;
wire clk_en;
wire [ 3: 0] data_in;
wire [ 3: 0] read_mux_out;
reg [ 3: 0] readdata;
assign clk_en = 1;
//s1, which is an e_avalon_slave
assign read_mux_out = {4 {(address == 0)}} & data_in;
always @(posedge clk or negedge reset_n)
begin
if (reset_n == 0)
readdata <= 0;
else if (clk_en)
readdata <= read_mux_out;
end
assign data_in = in_port;
endmodule
Could you post your top-level entity instead. Your pin assignments are right.
Thanks for helping me. Here is my top level entity :
module niossram (
// inputs:
osc_clk,
reset_n,
button,
// outputs:
flash_ssram_a,
flash_ssram_d,
led,
ssram_adsc_n,
ssram_bw_n,
ssram_bwe_n,
ssram_ce_n,
ssram_clk,
ssram_oe_n
input osc_clk;
input reset_n;
input [ 3: 0] button;
output [ 23: 0] flash_ssram_a;
inout [ 31: 0] flash_ssram_d;
output [ 3: 0] led;
output ssram_adsc_n;
output [ 3: 0] ssram_bw_n;
output ssram_bwe_n;
output ssram_ce_n;
output ssram_clk;
output ssram_oe_n;
wire [ 3: 0] led_n;
wire [ 3: 0] button_n;
assign ssram_clk = osc_clk;
assign led = ~led_n;
niossram_sopc niossram_sopc_instance
.in_port_to_the_button_pio (button_n),
.adsc_n_to_the_ssram (ssram_adsc_n),
.bw_n_to_the_ssram (ssram_bw_n),
.bwe_n_to_the_ssram (ssram_bwe_n),
.chipenable1_n_to_the_ssram (ssram_ce_n),
.address_to_the_ssram (flash_ssram_a),
.data_to_and_from_the_ssram (flash_ssram_d),
.clk (osc_clk),
.out_port_from_the_led_pio (led_n),
.outputenable_n_to_the_ssram (ssram_oe_n),
.reset_n (reset_n),
endmodule
You don't have connected the "button" input to your PIO
--- Quote Start ---
--- Quote End ---
or you should have this statement
--- Quote Start ---
assign button_n = ~button;
--- Quote End ---
The statement
--- Quote Start ---
--- Quote End ---
should be
--- Quote Start ---
assign led_n = ~led;
--- Quote End ---
Thank you very much !!!
