Programmable Devices
WIRE buffer
So why exactly do we need to use a WIRE buffer? or any kind of buffer?
to slow down the signal?
Michael
What's a wire buffer? You mean a "wire" primitive in Verilog?
Yes, the "wire" primitive under the category buffer.
Do you know what's the purpose of using WIRE?
Michael:)
The "wire" primive is meant to be a way to connect things.
Put simply, a Verilog wire primite is really the same as a wire in a circuit schematic.
Ie, if I instantiate a module, I need to use wires to connect it's outputs.
I also need to use wires to handle tri-state.
I can also use wires for combinational logic.
There's no delay or whatever associated with a wire.
rbugalho,
Thanks!
Mic
