Programmable Devices
21611 Discussions
Warning Messages Max+ Plus Advanced Synthesis
Please help me about of warning messages after compiling in Max+Plus Advanced:
Warning: Output pins are stuck at VCC or GND
Warning: Ignored unnecessary INPUT pin 'CLR'
Warning: Ignored unnecessary INPUT pin 'a'
Warning: Ignored unnecessary INPUT pin 'b'
this is my design in vhdl:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY mono IS PORT(
CLR, A, B : IN BIT;
Q, NQ : OUT BIT);
END mono;
ARCHITECTURE behavior OF mono IS
SIGNAL L : BIT;
BEGIN
PROCESS(CLR,A,B,L)
BEGIN
IF (CLR ='0') THEN
L <= '0';
ELSIF (A = '1' OR B = '0') THEN
L <= '0';
ELSE
--L <= '0','1' AFTER 252NS;
END IF;
Q <= L;
NQ <= NOT L;
END PROCESS;
END behavior;
and nothing else, but I dont' know that is wrong!
L is set to '0' in all cases, thus all inputs are ignored. That's what the warning says.
The line --l <= '0','1' after 252ns;, that is disabled by a comment won't by synthesizable, the "AFTER" construct is only valid in simulation. You can't build a monoflop without a clock.
Thanks for your help. I'm creating a monostable in replace of 74123. But I have trouble in setting the duration of time of pulse in high. Which would be the instruction for this?
