공지
21615 토론
What IP should be used to write, read and erase MT25QL512ABBE12 flash device from Cyclone V FPGA?
CBar-
초급자
1,129 조회수
I tried using altasmi parallel IP but when I write to the device I get an illegal write indication, even when I see in the status register that the flash is not protected. Should I use a different IP? or is there an example on how to preform write and erase operations using this IP?
I'm using quartus 18.1​.
0 포인트
1 응답
ShafiqY_Intel
직원
928 조회수
Hi CBar-,
For MT25Q flash device, I usually recommend my customer to use the following IP:
  • ASMI II parallel IP
  • Generic QUAD SPI Controller II IP
  • Generic Serial Flash Interface (GSFI) IP
For reference design, you can refer to following link:
0 포인트
응답
