链接已复制
1 回复
This is in your HDL code for inferring the RAM. If you initialize your RAM in the process of inferring it in your code, it automatically creates a .mif file to initialize the RAM at configuration time. If you're adding a RAM to your design as IP from the IP Catalog instead of inferring in your code, you would not need to worry about this.
#iwork4intel
