Programmable Devices
21592 Discussões
Which pins for ethernet transmitter in Cyclone IV GX?
Colaborador honorário II
1.174 Visualizações
Hello everyone,
I have an ethernet design which I got from internet with the outputs Ethernet_TDp, Ethernet_TDm. I thought the compatible pins for the outputs would be C1 and C2, but their I/O Standard is 1.4-V PCML which is not supported by default I/O Standard. Can anyone tell me how to resolve this isue?
5 Respostas
449 Visualizações
As far as I know, if you are using the dedicated tranisceiver pins, the transmitter I/O standard is 1.5V PCML while the receiver supports multiple I/O standards including 1.4V PCML.
You can check out the I/O standards in the data sheet or the handbook (i forgot which one had it).
449 Visualizações
There is 1.5V for the voltage level of the data going down the ethernet cable?
449 Visualizações
I read the manual at altera.com/literature/manual/rm_civgx_trans_starter_board.pdf, the I/O Standard for ethernet is 2.5-V CMOS (page 5), and the I/O Standard for pin C1, C2 is 1.4-V PCML (page 21). I don't know to set them up. :confused:
449 Visualizações
I find file "shematic in install folder" it show detail shematic. I remember having. good luck
449 Visualizações
--- Quote Start ---
--- Quote End ---
I searched every where, but I could not find it. Can you tell me the specific path? :D
Responder
