21615 Discussions
Working c project for "qspi" read and write from hps arm controller baremetal
hsaee6
I am new developer for the Cyclone v SoC.
I want to read and write from the QSPI flash in my HPS baremetal application. I want to write a very simple data in words format.
e.g.
write data 0xABCD, 0xCDEF, 0x1234
and then read it back.
I checked the following functions but they are not working for me.
alt_qspi_write
alt_qspi_read
I think i need to initialize the qspi and do the other initialization etc before using alt_qspi_write or alt_qspi_read.
Is there any one who developed a c program for QSPI of DE0-NANO-SOC?
is there any built application project doing the simple read and write on QSPI?
Esteban_D_Intel
Hello hsaee6,
Thank you for posting on the Intel® communities.
I would like to inform you that we have a specific forum for this matter.
I will proceed and move your question to the appropriate support in order to continue with the assistance.
Best Regards,
Esteban D.
Intel Technical Support Technician
hsaee6
i found the answer to my question.
in attachment is the source code.
you can import the code in the DS-5
then in the main.c you can find the QSPI read and write.
EBERLAZARE_I_Intel
Unfortunately, we do not have example in baremetal environment, if you opt to there are examples in:
https://code-time.com/default.html
If you want to access the QSPI in the HPS side, you need to configure it first, you may refer below for guidance:
https://rocketboards.org/foswiki/Documentation/SocBoardQspiBoot
https://www.intel.com/content/www/us/en/programmable/documentation/lro1404103165481.html
