Programmable Devices
21611 Discussions
a simple code showing a latch in quartus II?
Hi i am working in system verilog and a simple code like
always_ff @ (posedge clk , negedge rst_n)
begin
if (rst_n==1'b1)
begin
x<=a;
elseif (i==1'b1)
begin
x<=x+1'b1;
end
end
i am not using the exact name but the code is exactly the same where i is an input pin to the module.
its showing 2 warnings
Warning (13004): Presettable and clearable registers converted to equivalent circuits with latches. Registers power-up to an undefined state, and DEVCLRn places the registers in an undefined state.
and
Warning (335093): Timing Analysis is analyzing one or more combinational loops as latches
for x these warning are coming.
You can expect this warning for all recent FPGA families that don't have both asynchronous set and reset provided with their registers. They need to implement a rather complex circuit with a XORed data path on both sides of the register and a latch holding the asynchronous preset value. Besides the reported restrictions, the construct involves additional delay.
The preferred solution is to avoid an asynchronous variable preset.
Yes i was facing an additional delay when i checked the timing reports.
Thanks for the reason...
