Hi i am working in system verilog and a simple code like
always_ff @ (posedge clk , negedge rst_n) begin if (rst_n==1'b1) begin x<=a; elseif (i==1'b1) begin x<=x+1'b1; end end i am not using the exact name but the code is exactly the same where i is an input pin to the module. its showing 2 warnings Warning (13004): Presettable and clearable registers converted to equivalent circuits with latches. Registers power-up to an undefined state, and DEVCLRn places the registers in an undefined state. and Warning (335093): Timing Analysis is analyzing one or more combinational loops as latches for x these warning are coming. ThanksLink Copied
You can expect this warning for all recent FPGA families that don't have both asynchronous set and reset provided with their registers. They need to implement a rather complex circuit with a XORed data path on both sides of the register and a latch holding the asynchronous preset value. Besides the reported restrictions, the construct involves additional delay.
The preferred solution is to avoid an asynchronous variable preset.- Mark as New
Yes i was facing an additional delay when i checked the timing reports.
Thanks for the reason...
