i want to make a Tri-State Logic gate,but the putout is always high impedance .why
here's my code; library ieee; use ieee.std_logic_1164.all; entity e is port( datain:in std_logic_vector(7 downto 0); enable:in std_logic; dataout:out std_logic_vector(7 downto 0) ); end e; architecture b of e is begin process(enable,datain) begin if (enable='0') then dataout<="ZZZZZZZZ"; else dataout<=datain; end if; end process; end b;Link Copied
dataout needs to be an inout to have a tristate
but is the problem in simulation or on hardware?
in simulation.but it's so strange.today i try again.when enable is 1,dataout is same as datain.but when enable is 0,dataout is always 0.so my question is changed.dose 0 stand for high impedance in quartus ii?
anyone?help.
did you make dataout an inout port? it wont work as just an out port.
And is this an RTL simulation or post place and route?- Mark as New
thank you.when i change dataout to inout,it works well.at first,i thought "inout" means "buffer",because i never learned inout.
inout is needed for tri-state buffer on real hardware.
a "buffer" type is an output that can be read internally (it is NOT tri-stated). It is quite rarely used, as most coding guidelines recommend you use internal signals instead.- Mark as New
can you tell me why
you cannot read an out port, so there is no need to tri-state it. Because of that your logic got converted to a mux.
I am assuming you did a post compilation simulation, because you would have seen no problems with an RTL simulation (and then the differences between hardware and simulation would have caused you problems).- Mark as New
thank you very much
