Programmable Devices
about niosII
I write in NiosII this instruction
int a,b;
int r;
a=4;
b=98;
r=a&&b;
the problem i have a message error ,when i use && ,I don't know why ?
can sameone help me to use this commande && ?
thank you
The sintax is correct.
What's the compiler error message?
PS: I'd recommend spaces to separate && symbol (logical AND); although this is not mandatory, it will improve code readability.
i try with espace but i have the some error
this a part of code of erode
int **IM ,**im1;
unsigned char r,u,ml,mm,mr,d;
for(int i=1;i<height-1;i++){
for(int j=1;j<width-1;j++)
u = im1[i-1][j];
ml = im1[j-1];
mm = im1[j];
mr = im1[j+1];
d = im1[i+1][j];
r= (u && d) && (ml && mr && mm);
im[j]=r
this code turn witn succes under visual c++ but under nios II a i have this error: expected unqualified-id before
processeur failed
--- Quote Start ---
--- Quote End ---
You can't define variables inside the for loop instruction.
This mode is not supported by Nios C compiler.
Declare i and j with other variables.
--- Quote Start ---
int **IM ,**im1;
--- Quote End ---
IMHO this declaration is ambiguous if you then use these pointers to address a bidimensional array.
You don't specify dimensions, so, how can compiler know how to map array indexes to memory?
--- Quote Start ---
IM[i][j]=r
--- Quote End ---
Semicolon missing
Cris
defining variables in for loops is legal in C++, but not in C. Visual isn't a 100% compliant C compiler and sometimes lets you do non standard things ;)
The biggest problem with this code is that you use the IM and im1 pointers without assigning them a proper value first. This will probably crash in most cases.
You should define static arrays instead.
